Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 54
Thread: Did my EGR delete!
  1. #31
    sydney nsw
    what about 2.5?
  2. #32
    sydney nsw
    finally done it. cant see what all the fuss is though. cant feel any difference at all. it is a good thought though that im no longer sucking up rubbish. do wonder if its normal for egr to have so much oil in it and where does it come from? and also what is the purpose of the butterfly on the egr valve? i noticed it never moves whatever the revs are.
  3. #33
    Quote Originally Posted by jfoldbar View Post
    butterfly is there as a shut of valve for the engine I believe.
  4. #34
    Oct 2010
    http://ovh.jazdw.net/SSP_368_The_2_0...technology.pdf
    Enjoy.
    Golf GT Sport TDI
  5. #35
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by GoLfMan View Post
    That, and it works to increase vacuum past the EGR inlet, to draw in more or less EGR. It's a restriction, pure and simple.
    It is absolutely necessary to do a regen if you have a DPF - GT TDI/Passat in MKV or all MK6 TDI's.
  6. #36
    sydney nsw
    i got thinking, when i done delete, should i have disconnected vacuum hoses from it so butterfly cant work. if it moves after delete engine cant get any air and will choke. what should i do with hoses when i take them off. since they still have vacuum they could suck up dirt if they are just hanging around.
  7. #37
    Dec 2009
    Kew, VIC
    If you disconnect vacuum hoses you should also block them off — quite apart from any dirt (which your engine wouldn't appreciate) the air leakage will upset things no end.
  8. #38
    sure does! Big fan of the new driving experience
    however my only gripe is by getting rid of the flap, shut off is a lumpy affair, scared the crap out of me when I first turned it off, but then I worked it out and it was all ok
    Really? I found it to be about the same as normal but mine is fairly rough anyway. I'm getting no bites on selling it so I'm just about to order the diesel Geek turbo kit and a FMIC.
    2008 VW Polo TDi
    GIAC | REMSA | PD160 | DECAT | MUFFLERECTOMY | ECS | SUPERPRO | PXL KIWI WIFI | 312mm BRAKES | OZ RACING | KUMHO V70A
    To Buy: VNT 17/22 or K3 Turbo | R783 Nozzles | Intercooler | Water meth kit.
  9. #39
    Quote Originally Posted by Evaded Motorsport View Post
    the 17/22? how much will that turbo set you back? Its got me thinking because my outing at the track the other day left me wanting more power
  10. #40
    Nah, going the 1756VK or the 2056VK 17/22 has issues with EMP. Budgeted the next stage of the build. $8,200 give or take lol.
    2008 VW Polo TDi
