Originally Posted by
gldgti
Although it seems silly at first glance in terms of control, VW (and most other car makers) have had load governing devices on diesel engines for a long, long time (30 years or more!) - Every vw diesel ever made (possibly not including the diesel beetle of the 50's that noones ever heard of
The mechanical pump diesels (prior to PD engines) use a flyweight governor in the pump to reduce fuelling as the rpm increases, for the same accelerator position. The flyweights work against a staged spring system connected between the accelerator and the fuel control collar - what this means is that under light loads, the fuel supply will change depending on engine load - so if you are cruising along and you start going up hill, the engine speed decreases and the pump starts adding more fuel to compensate. Similarly, as you start to go downhill, the engine speed increases so the pump starts to cut fuel to compensate.
The only difference between the old system and the new, is that these days its entirely electronic
Ahh i see, i see !
yeah it definitely feels like an electronic thing haha
cheers mate
Mysticality
Almost sounds like what mine does, going down hills... Accellerates enough and then drops power and begins to coast down. (0L/100km and 0% engine load)
A bit un-nerving, but I can replicate it 100% on a couple of specific hills in the area!!
glad to know im not the only one lol
Ive just learnt not to touch the accel pedal as i coast over those hills
mk6 TDi - DSG -VIEZU tuned- Carbonio . Whiteline RSB/Neuspeed FSB . Golf R interior . Defi boost . Twin 4" Magnaflow tips . GTI shocks & springs
