Thats good Phil.
Are you at work in the arvos?
I`m thinking Thursday or Friday.
Depends whether the Mrs is having a baby or not tho.
If so, it`ll have to be next week.
What do you do, 1,000kms per week?Originally Posted by Edison
Matt let me know when your going there. If you forget something I am only 5 minutes away. I think you need a special tool to hold the cam or something from memory.
Thats good Phil.
Mostly arvos. Just call me when you know so that I will expect you.
Do you have a manual?
At 60kph, the aerodynamic drag alone for a VW golf is just under 3kW (4hp), and it increases with the square of the velocity. Add to this, rolling resistance (even if you can halve the rolling resistance), and you still have 7 or 8kW. Simply not possible to run the golf on a 2hp motor at any speed greater than two thirds of bugger all.Originally Posted by Edison
If you have a source of cheap nimh batteries, i'd like to know where you're finding so many at so cheap! A standard size battery pack for an EV in Ni-mh is about $15000. Lead acid is the only way to go in these times and economies.
Smithy
Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
1976 LS parts vehicle
Used to have: Mk1 Swallowtail LS DIESEL!
Sounds fantastic, I think it may be possible to put it back together again in the same spot, I'd put in 120% effort to do that, cause I'd be rather excited to have it going together, and keeping the dust out, maybe it can be towed with the new head in place but not timed? I dunno...Originally Posted by Golf Loon
I'm a male model, so i know even less, but I expect paint, scratches and drawings of the positions of the three big cogs should be enough. Maybe it should be rotated into TDC first also? don't know..Originally Posted by Golf Loon
Perfect, as I said, whenever is ok for you is 100% for me I've moved everything I was even thinking of doing.Originally Posted by Golf Loon
...when you say early in the arvo do you mean BEFORE 8pm?
alternate energy vw enthusiast....and general crackpot
I don't have any special tools at all, but I have helped a friend change the waterpump on another kind of car, which required timing belt removal and replacement, it went fine,.Originally Posted by syncro
I'd love to do at least 1,000kms a week, it's 800 round trip from the country to sydney and if fuel is free I'll do more when there's not much to do. Smoking and midnight zoo are not as attractive to me as hobbies as is looking for stuff in council cleanups.
I suspect you may be correct, although the dc motors are usually driven into overload on startup, about 10x power is the usual, I think i'll just go for double the rated voltage which should provide 4x the power, or maybe triple volts, and 9x the power.Originally Posted by Smithy
However, yes, it will be modest. But the car would allow some suburban driving which is usually tame and full of red lights. A car that would allow me to get to the train station (same as shops) and back, or to pastors house and back would be of great benefit, saving in fuel and maintainance on the normal cars. after that, another motor would be in my sights.
It would be monumentally useful for all the short trips, and let me know just what the measured rolling resistance is, in kW's! and the power consumption, and I can make better estimates...
hey this is aydan (gld gti) not mollins - i have a broken internet atm.. hehe
ed, you need to give fred a ring at VSI Imports in SA. google in VSI Imports and you should find em. give em a ring, a head gasket in any size is less than $70 im sure, atm.
if your little golf of hope was running semi ok before, i can give you some hints as to what you'll find:
- badly blown head gasket (you already know)
- worn valve guides and seats
- maybe worn rings
what sort of km on the engine? if its less than 200k, dont worry too much. replace the head gasket. check for bad wear in the valvetrain, if you can afford some new head components do that.
on putting it back together, use a careful head bolt tightening sequence. dont be afraid to vary from the manual in putting in a few more steps - takes longer but is worth it
btw, you need 11hp to cruise at 100km in a mk1
TDI mk1 on the road!!
I do think it will be very worn, and I'd be happy to spend the extra on fixing it up so long as I can save the money first of course, and so long as it looks like a goer. it's 265k now, but I *never* take that to mean dead as some people do, it's never the best indicator of wear and tear. Not nearly as good an indicator as actual wear and tear itself. I'll spend as much time and extra steps as I can, thats no problem at all, results today are more important than the few extra minutes you put in a year ago.
It's on the street and so for degreasing it I found a manual pressure sprayer I can use with the degreaser to wash it down 1st. not done yet...
Of the 11hp, how much is wind resistance and how much is drive train, tyres, etc ?
Also I almost never cruise at 110, not on the country roads. Though when I do an electric car, I probably will. Because if I am designing a computer or more for the car, I can include a simple driving aid for potholes and the like.
I think if the odometer was linked to a computer you could enter all the nasty little things you find like potholes into it so it can make a file of your common journeys and warn you when you are approaching a nasty item so you don't go over it and ruin your wheels. it would know speed of course from the odo link, it could also keep track of cameras and speed limits, possibly even take over the whole cruise control thing... but so easy cause it just needs one sensor and your occasional input.
Right Edison, call me as your phone is not working mate.
I have a few ideas for your car, not all bad.
Talk to me man
edison www.busdepot.com is a cheap place to order head gaskets. allow a week or 2 to get it cause they come from US. find out how many notches you require i have a 4notch u can have
\"mother natures quite a lady but your the lady for me\" - johnny cash.
