Originally Posted by jets I thought only 507 is approved for engines with a DPF. 504 is the petrol spec. I haven't seen a 507 yet that isn't 504 & viceversa. So you look for one & see the other
carandimage The place where Off-Topic is On-Topic I used to think I was anal-retentive until I started getting involved in car forums
It's also easy to forget 'voltage' which can be an issue on 'e' cars causing weird pop ups. Voltage can be the forgotten factor in some cases. How old is the battery?
View Tag Cloud
Forum Rules
