Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Dashboard warning lights on and Faulty codes
    Erskineville, NSW
    Quote Originally Posted by jets View Post
    I thought only 507 is approved for engines with a DPF.
    504 is the petrol spec. I haven't seen a 507 yet that isn't 504 & viceversa. So you look for one & see the other
    Feb 2014
    Central Vic
    It's also easy to forget 'voltage' which can be an issue on 'e' cars causing weird pop ups. Voltage can be the forgotten factor in some cases.
    How old is the battery?
