Results 1 to 5 of 5
Thread: cylinder liners for diesels
    Aug 2009
    Vancouver Island BC Canada
    I have seen vw diesel cylinder liners listed on Ebay.
    It seems like a way cheaper route to bore out the engine and put liners in and reuse the old pistons (new rings and bearings of course) than buy new oversize pistons and rings. This is a fairly common practice on industrial engines
    Anyone with any experience or advice on this in vdubs.
    Grumman Kubvan, 1.6L TD
    Exploring the Salish Sea
    Adelaide hills, SA
    Quote Originally Posted by 49thdiver View Post
    I wouldn't reuse the old pistons, since pistons wear out too (incl. groves for the rings). You should replace pistons when fitting new liners.
    Taree NSW
    Sound advice especially if the engine has several hundred thousand kilometres up.
    Carer for my partner's Eos 2.0 TDI DSG MY09 Candy White/Cornsilk Beige leather trim.
    Aug 2009
    Brisbane Sth
    new liners arent easy either
    changing liners can be a problem also, as chevy found out with the alloy block LS1 they move if not fitted correctly or because of different thermal expansion rates of dissimilar metals, new pistons and rings is the easy way out.
    Spark ignition is a threatened species
    Biodiesel is the best emission control money cant buy
    MK1 5 door Mexico Beige 5/79 Golf GLD 1.5
    Taree NSW
    Quote Originally Posted by oracle1 View Post
    The liners have to be an interference fit to stop this problem - the best way is to use dry ice [approx -30deg C] or a dry ice/acetone solution [approx -100deg C] to freeze the liners before insertion [just don't drop them] and the low temperature allows time to ensure they are properly positioned before the interference fit takes up.
