bump!!!!!!!
hey all unfortunately my clutch has started slipping quite considerably and im after a quick replacement GAP has this but im not sure if this is the right size as it says its for a later model
GermanAutoParts.com
bump!!!!!!!
anyone got an idea
Does the car have a cable change gearbox. If it does then that clutch should do you. If it has a rod change box which I reckon it should then back to the drawing board.
Looking at ETKA now BRB
Rod box, 210mm
http://www.germanautoparts.com/Volks...lf/Clutch/55/4
Should be the same fit as a 2 litre, ETKA doesn't give me the details of the plate though. The box should have the larger input shaft of the 2 litre box.
you'd think the tdi mk3 would use an 02a style gearbox with cable change.
the clutch diameter is the same which would lead me to believe that if they had the same input spline, then it'd fit.
why not go for the HD GAP clutch kit for the vr6?
87' MK2 GTI
13' MK7 TDI
jayjay, it has a rod box mate. I looked on ETKA.
It would have been a bind pulling the box off, to find you had the wrong one for sure.
Give me all your details im getting bumper prices for clutch kits at the moment
Jmac
Alba European
