![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
koolerking
Oh, should i be worried what else could be causing smoking through the rev range, with a strange "pulsing or hesitation when the throttle is held around 2-2300 RPM. The rest of the engine is fine, no lack of power. Could it be injectors?
EDIT: its actually only smokes from 2 to 3000rpm on hard acceleration or going up a hill, then its clear.
Sounds like its normal to me - they all smoke under hard acceleration. Unless you have a DPF filter which your car does not.
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
