Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 99
Thread: Cleaning the EGR and Inlet on a GT
    Adelaide hills, SA
    Quote Originally Posted by Greg Roles View Post
    Good point, I can only speak for the 125kw!
    The thread is named GT, so you're right. I only noted just in case that someone with just MK5 TDI would want to follow the instructions.
    and just a hint, if you reuse the rubber gaskets (Orings), you can use Loctite 515 or 518 on them to increase reliability, but it is always better to re-new the gaskets, especially when they aren't expensive.
    Nov 2007
    The only way to drop it is a Provent/Can, manual cleaning, and an EGR delete or minimisation, but there's things to consider in doing that, especially in the oilers. You're mad not to run some sort of can in a direct injection engine you intend to keep beyond 100k.
    Do you really think that a Provent or some kind of catch can will really stop this? I ask because you posted much earlier this -
    http://www.vwwatercooled.org.au/f28/...-28464-16.html
    Your EGR valve looks just about a filthy as mine and at this stage your car had a lot less mileage than mine and you had a Provent installed.
    Could that gunk perhaps be coming from that exhaust pipe thats running into the EGR valve? ( In which case a Provent wouldn't help )
    I noticed that the actual flap in the valve thats facing the intercooler hose was the cleanest side of the EGR valve whereas if all the gunk was coming from crank case blowby flowing through the intercooler hose it would be the dirtiest?
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    Jan 2008
    Sunshine Coast
    You have a good point, but the main difference is my buildup was dry soot, whereas yours is more the typical wet sludge. I can't see a catch can stopping the EGR soot buildup, which does seem to happen in my case, but it does remove the oil film all through your intercooler and pre flap plumbing, and as it removes extra oil from the combustion chamber, it has to be a good thing for oil ash blocked DPF's. The perfect solution is dropping or deleting the EGR and using a catch can, but yeah, if you are prepared to pull it apart every 50k or so, you can survive just fine without a can ( in a non DPF car ). I figure a $175 Provent is a lot cheaper than a $4200 DPF, and I had always planned to keep the car well into DPF blockage territory at an approx 150k, so anything to extend that event is fine by me!
    Then you get into the carbon deposit theory on the valves....... the price of a catch can seems minor in comparison.
    Nov 2007
    The perfect solution is dropping or deleting the EGR and using a catch can.
    So has anyone got a decent and effective EGR delete kit out yet for the GT? From what I've read its not so simple.
    Adelaide hills, SA
    Using good fuel additive could help. Since you have the DPF try Wynns Diesel Power 3, Diesel Clean 3. Wynn's Belgium bvba
    The Diesel Power 3 looks very promising on the paper, I will pick up the box next week and give it a go.
    May 2007
    Specs look good on the above and DPF safe.
    Let us know the price and how they go...
    Jul 2005
    I wouldn't do it. Volkswagen don't recommend fuel additives, neither do the fuel companys.
    Maris
    Jan 2008
    Sunshine Coast
    VW want to sell $4200 DPF's mate.
    If you delete the EGR the ECU is going to throw an error due to O2 levels being too high, and the EGT's and emissions will skyrocket. Melted turbo is the main problem, and I'm only deleting mine in conjunction with lots of breathing mods, intercooler mods and mainly water meth injection. It's so far from simple I am still looking for the solution tune wise.
    Jan 2011
    Adelaide SA
    Just two weeks ago I cleaned ours (1.9 TDI) Only cleaned the throttle body (is that what its called?) most diesels don't have one, and the EGR . Was going to post some photos, they look very similar to Poyta's anyway -pretty bad, blockage must have reduced diameter of inlet by 30%, car has done 62000ks . Didnt take off the manifold as only had a couple of hours to do it. Easy to clean with caustic cleaner toothbrush and water pressure. Think car has improved mileage, steady trip to the hills and back of 40ks showed 3.7 However seems to have gone back to normal now.
    Greg said "If you delete the EGR ......and the EGT's and emissions will skyrocket." On ours the EGR port was partially blocked yet it still ran the same. The port is fairly small compared to the inlet. I'm wondering just what real detriment will be caused to a 1.9 which is not driven to the max except for a few seconds once a week or less, if the EGR flow was reduced.
    Jan 2008
    Sunshine Coast
    It's your turbo mate, but I'm measuring dangerous EGT's stock in my GT, and EGR is all about lowering combustion temps to lower NOX emissions. I know in the 1.9 you can drop the EGR with Vag Com, do a search on TDI club for details. Not so lucky with the 2.0, and I am hoping Parso Rex can code mine out for me. There are EGR delete tunes available in the UK. Remember you need to factor in extra cooling, and that's both for the turbo's health AND those nasty NOX emissions. In the least you'd be mad to do so without a decent EGT gauge.
