Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 99
Thread: Cleaning the EGR and Inlet on a GT
  1. #41
    Quote Originally Posted by Greg Roles View Post
    It's more that the 200 has the lowest restriction of the two, and you want to minimise restriction in any PCV system. In light of that, if you have space, overkill is the answer!
    Hi, with these provents do you need to change anything else, i read on another thread you talked about cooling mods, or is that if you chip?
  2. #42
    Jan 2011
    Adelaide SA
    Quote Originally Posted by koolerking View Post
    True!
    Are the manifold heads Torx? (last time i looked at a vw head it was a beetle, 14 years ago and they were hex! )
    Can you soak the manifold and ECG with the degreaser, and the attack with a brush?
    FWIW I have found the easiest way to remove stubborn carbon and greasy deposits is with a caustic cleaner, like oven cleaner, draino, or mild caustic soda (NaOH) and water, also some engine cleaners are slightly caustic and more gentle on aluminium. Liquid hydrocarbons like carb cleaner are fairly weak with carbon and only dissolve the grease. Use a nylon brush or toothbrush as caustic will eat up hair brushes and any other carbon based material (like skin) Wear specs and rubber gloves. Method just gently brush on solution, wait a while then rinse off with lots of water from hose. A plastic manifold could be soaked for a few hours then washed spotlessly clean with no damaging scraping or chipping needed.
  3. #43
    Would you say the EGC and intake clean would stop smoking on acceleration?
    My first Modern VW!
    2005 Golf 2.0l TDI, DSG.
  4. #44
    Adelaide hills, SA
    Definitely not, your Golf has PD injectors that are less precise in controlling the amount of injected fuel.
  5. #45
    Oh, should i be worried what else could be causing smoking through the rev range, with a strange "pulsing or hesitation when the throttle is held around 2-2300 RPM. The rest of the engine is fine, no lack of power. Could it be injectors?
    EDIT: its actually only smokes from 2 to 3000rpm on hard acceleration or going up a hill, then its clear.
    My first Modern VW!
  6. #46
    Nov 2007
    Sounds like its normal to me - they all smoke under hard acceleration. Unless you have a DPF filter which your car does not.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
  7. #47
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    What fuel are you using. Try changing fuel companies.
    You could try BP and I think some caltex have the new higher rated vortex diesel in Sydney.
    I only use the good stuff from BP and still get the puff of black smoke when you hit
    the accelerator hard but that's what I like to see out the back.
  8. #48
    Quote Originally Posted by poyta View Post
    Thinking about it its probably not even under hard acceleration. In fact hard acceleration gets it "though" the smokey bit of the rev range. it seems to do it even up a gentle incline. It makes me think its when the turbo spins up, which could equal major problems, maybe the turbo seal?? Hope the new car isn't turning out to be a certain fruit.
    My first Modern VW!
  9. #49
    Gosford Central Coast NSW
    probably its just regenerating the dpf... or trying to.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  10. #50
    I didn't think the 2005 2.0l TDI's had a DPF, is that right or wrong?
    My first Modern VW!
