Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: Clean up
  1. #21
    Dec 2008
    Perth
    Here is the minimum what I would do:
    Before parking in the garage;
    Fill up the tank and put good quality diesel additive to protect from the algae.
    Block the inlet and exhaust so no moisture can get in.
    Jack the car up and put it on the stands so the wheels are not touching the ground.
    Connect the C-Tek battery charger to the battery (without disconnecting the battery). Unless the battery is Optima or similar in design (for starting the vehicle after lets say 6 months).
    After following these instructions, this is what it should look like:
    MY14.5 VW Polo 81tsi Comfortline - Candy White - Comfort Pack
  2. #22
    Adelaide hills, SA
    Hey Greg, how did you go with that blue silicone hose for provent? Did you get rid off any elbows?
  3. #23
    melbourne
    Quote Originally Posted by Coaster View Post
    damn you for making me cry.
    good info though tranny- that's the kind of forethought i wish i had.
  4. #24
    Feb 2010
    this made my night hahah.
    Without Your Seatbelt, You Know Your Gonna' Die!
    Project: mk1 cabriolet 20vt
  5. #25
    So when is the entire system getting beefed up then?
    Heads, cams, inlet manifold, turbo etc
  6. #26
    Adelaide hills, SA
    Clean up
    Please do not post in it!
  7. #27
    Adelaide hills, SA
    I've got your Tig as $41890 with your options and the 147 at $42990 ..... but more importantly and something thats not mentioned often ....
    The TDI Tig has a DPF, yes? .... and that is not suited at all to sustained city driving ..... so add the cost of replacing that (and its not covered under warranty) frequently ..... and its expensive ....
    Our Touareg has the DPF and driven in the city, so far it is fine I check the particle loading and don't expect it to be a problem (should easily pass 200,000km)
    Sharkie, if you remember; what was your average fuel consumption before chipping?
  8. #28
    Adelaide hills, SA
    Yeah I wouldn't go larger than 3" as well. Our Touareg 6 cyl TDI is 2.5".
  9. #29
    im going 3" when i go a GT2260vk
  10. #30
    melbourne
    hey josh is that bolt on? cant be....
