2.0 tdi 103kw, comfortline, dsg, it is an 08 model, that's what it was, now wow no acceleration lag from stop and turbo thrust.
Printable View
Having recently spent some time on erwin, and having just read the 125kw self study manual, the differences are according to VW themselves:
Different injectors and higher pressure
Bigger turbo, different actuator mechanism and more accurate sensor
Lightened but forged crank - 4 counterweights instead of 8
Extra cooling channels in the block, especially around the injectors
Different EGR, with much larger exhaust gas cooler
Different head, lower profile valves, different pistons, trick headgasket
Changes to the inlet manifold, more agressive dual port inlet design with active swirl flaps
So definately a lot more than a re-map!
Have any of you guys with the 103kw motor with bluefin put your car accross the dyno yet . Im interested to see the results. Thanks
do you mean different injectors or a different fuel delivery system? don't piezzo injectors run off commonrail?
the gt also has a DPF! suckers! j: delete!!
Power and torque wise, it possibly will be.
But the changes VW made aid the responsiveness, just consider the crank design, lightened and less counterweighted, yet forged for strength. Would make for a revvier diesel, as much as there are revvy diesels....j:
Most importantly, VW considered the long term survival of the engine. Just the exhaust gas recycling cooler alone is massively different between the two vehicles, the normal TDI has a very basic cooler, and the GT has a full on liquid cooled active bypass tube design about twice the size. Just that alone is designed to cope with higher exhaust temps, so a remapped 103kw will quite possibly be overloading systems such as this.
I was amazed just how much difference there is between the two when I read both self study articles. It was pretty much a redesign from the block up.
very interesting, and good to know.
i still think that you comfortline can be chipped and driven hard without too much worry though, just as long as your prepared to make other changes like a large intercooler and completely new exhaust system optimised for low EGT's.... but i suppose, for the extra money, you would've bought a GT instead... hehe.
one day when mk5 golfs are old, THEN people can argue the benefits of buying a comfortline spec over the GT - it'll be like the GTI vs golf LS - buy the LS and mod the crap out of it, or buy the GTI and leave it stock :-D
