Hmm, not sure, I like quiet car.![]()
I took my car into an exhaust place today and got the pancake cut out of the back of the MKV! Felt like it was breathing a bit better and also had a *slight* change in note (no idea why VW insists on putting it on...).
Total cost $85I drove it for about 10 mins and wasn't happy with the noise (no different!), so I took it back and got the centre resonator cut out... So now I have a cat and nothing but straight pipe!
Cost an extra $50 to get that done
Now it sounds much better! It's a bit noisier below 2000rpm and you can hear the exhaust flowing above 3500rpm... Outside it must sound a lot louder, but inside it's OK (I wouldn't say 'quiet' and I also wouldn't say 'loud'). You do get a pigeon-sex type noise when you've backed off quickly, but other than that, you can hear the turbo spool easier too
Car picks up a lot better too, turbo seems to kick in about 1600rpm rather than 1800rpm like it used to... Not sure if it's faster 0-100, but response is definitely better.
Do it!There's a few clips on youtube of diesels with straight through exhausts and they aren't loud either...
yeah - i've done the stupid thing - i paid to have a "sporty" sounding muffler put on, and then a mufflerectomy...
NO difference in sound whatsoever, and the weight saving means i dont have to worry too much about eating too much pork crackling this festive season...
Well, after driving through a car park, it is quite loud outside! Not obnoxiously loud, but it doesn't have a "sporty" sound, but meh, I don't mind! Hearing the turbo heaps when backing off, sounds good![]()
I'm doing this with twin stainless tips ( gti style) on a gti back bumper soon, just need to head down to sydney and pick up the gti valance![]()
Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
I had the rear muffler deleted from the Tig and had it fabricated so i could swap between the straight pipes and the stock muffler.
All up it cost a little over $400 but it sounds great and the weight saving is definitely a bonus.
There's a point where it resonates a *little*, but that's pretty much spot on 2000rpm in 3, 4, 5, 6 gear and the corresponding speeds, so long as you are a touch above or below the speeds it's silent!
I've also noticed it's smokier too now, I assume the old soot filters (mufflers) were doing something! (mine is remapped...)
It sounds like you've reduced the ability of your exhaust system to save up for a good sooting at the appropriate occasion![]()
Resident grumpy old fart
Your wasting your time unless you remove the cat which is the real restriction in the system.
