'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Take a sample of the oil and send it off for analysis. That will decide whether it needs replacement or not.
The oil and filter is cheap, engine repairs aren’t.
Even if the synthetic oil is stored properly in sealed container, I still wouldn’t want it in my engine once is 2 years and older.
It’s completely different story once the oil is in the engine, it’s life is much shorter due to oxidation and all sorts of contamination.
It’s very rare to see the use by date on the oils, but the longest I ever saw was on 208L drum of Mobil1 ESP5W30 few years ago, and it was 5years from the production date. The oil companies usually don’t like to tell what’s the safe use by date of the oils.
If you drive just 2,000km per year or anything up to 10,000km, change the oil and filter every 6month regardless of km. Otherwise don’t keep the car longer than 5 Years.
