Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 116
Thread: Campaign 23H9 - 103kW/125kw TDI PD Piezo Siemens Injector Failure
  1. #21
    Jan 2013
    So the new injectors have fixed the issue?
  2. #22
    Apr 2009
    Gippsland Victoria
    Quote Originally Posted by Greg Roles View Post
    Yep Ipswich or Highway would be my immediate Brisbane choices.
    Approximately late 2008 VW "started" using double o-ring injectors "in some cars", as far as I can work out from the piddly amount of information VW release about this problem around the globe. You can have a 2008 model that will be fine, or you can have a 2009 model which is affected. If it is early 2008 like mine, that is build date, well you're in the firing line.
    This could all be totally wrong, VW won't confirm or deny anything.
    Nor will they pay for the cost of a towtruck for those in cars that fail before you can get them in for the recall.Glad that they have come clean now for those that haven't had this happen to them(injector fail), but the occurance and Lack of tow truck expense contribution, still leaves a sour taste in my mouth!
    Current:12 Golf GTD, Mods on order -Bluefin Remap, Mods planned-plenty
    Former:08 GT Sport TDI DSG Bluefin, HPA SHS Coilovers,H&R Swaybars with Whiteline Adj Links
  3. #23
    Albany, WA
    Quote Originally Posted by stormshark View Post
    They have not come clean in the real sense because they are not contacting people, whose details they should have on record, I mean how long would it take to send out an email, the "Recall" was issued in Feb 13 officially.
    To be honest if I was not a member of this forum, I would not be aware the car has this problem and that a fix has been issued by the company.
  4. #24
    Albany, WA
    Yes, they have been designed to fix the issue.
    @ Manol, any updates on the work??
    @Jimmy T, I might see you there lol.
  5. #25
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by JimmyT View Post
    Double o-ring oil seal will delay the issue dramatically. The fix was going back to Bosch in the MK6.
  6. #26
    Albany, WA
    Really, so all the campaign replacement is going to do is delay, not fix?
  7. #27
    Jan 2008
    Sunshine Coast
    I figure so, as the single o-ring injectors fail as oil eventually gets past the single seal, two will just last longer in my opinion. Probably dramatically so to be honest, as I am sure it's been redesigned to seal better as well. I expect the new injectors to outlive usual engine life though, but we shall see.
  8. #28
    Adelaide hills, SA
    Re: Campaign 23H9 - 103kW/125kw TDI PD Piezo Siemens Injector Failure
    Or it may fix the problem. Even if they'd just upgraded material of the Oring and used again the single Oring it could still be a permanent fix.
    Sent from my GT-N8000
  9. #29
    Sep 2008
    More info on the campaign here
    Injector Failures - Possible recall - Page 53
    Technical background
    On some vehicles with the 2.0l TDI engine, deposits can settle on the Piezo pump injector elements because of dirty engine oil. This can lead to running problems. Not all vehicles are affected by this campaign! On the affected vehicles the Piezo pump injector elements must be checked and if necessary replaced. Please make sure that on the affected vehicle the check and repair of all open campaigns/measures are performed during the workshop visit.
    Parts to be fitted as part of this campaign.
    1x Campaign 23H9 sticker 000 010 006
    1x Wiring loom adapter 03G 971 033 M
    4x Adjustment screw WHT 000 530
    5x M8x58 socket head bolt N 105 811 01
    8x M6x88 socket head bolt 03G 103 385 A
    4x Pump injectors
    Seems a bit weird that VW would replace injectors fouled by dirty engine oil without fixing the engine oil problem at the same... or has something else changed too like oil specification??
    2015 Polo Comfortline 6M + Driving Comfort Package
    2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
    (2008 MY09 Polo 9N3 TDI retired hurt hail damage)
  10. #30
    Dec 2008
    Sydney/Canberra
    Oil spec has not changed.
    I suspect that they've confused "dirty oil" with oil contamination of the injector internals.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
