It's true, when you car goes in to get serviced or something fixed as per VW Australia. The car has to come out exactly the same way and working, if it doesn't you go back and you get it sorted.
It's not like ABS AUTOMOTIVE or L & M MOTORWORKS or some generic company where any old hack can work on the car and somehow get a solution.
If a Volkswagen Dealer royally **** up and their workmanship is a complete mess you have an invoice and a list of works they have done which they are liable for.
My vote is check the battery. You have to have a healthy battery to spin the motor fast enough to actually start. As it grows colder, otherwise decent batteries start to struggle. I am on my third battery in 5 years, granted I swapped to a smaller one at first, but the last one that just gave out was a top dollar Odyssey, and only got two seasons. It was taking a few goes to actually start, new battery and it's back to starting like a charm.
Just one possible reason I have never found to be an issue on petrol cars.
when the injectors of this campaign do fail the car never starts again. thats why i would rule out injectors and have a fault code check done.. hopefully it has logged something....VDUB...
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
When was the last time the fuel filter was replaced?? No fuel getting through possibly??
EGR flapper gummed up and sticks shut?? Car still idles like that though....hmmm
Just got a call from Ian's, my car needs the replacements, but they need to order the injectors in so I cannot drive the car as the car is now suddenly "dangerous". I am surprised they hadnt ordered the parts already.
Now I am stuck with a petrol Polo till Monday.
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
