Results 1 to 9 of 9
Thread: BP Ultimate Diesel - specification changed????
    Sep 2008
    BP Ultimate Diesel's product sheet, as currently available from BP website (Issued : 21st February 2008 ) claims a cetane number of min 50, typically 55.
    http://www.bp.com/liveassets/bp_inte...o_25022008.pdf
    BP Ultimate Diesel's product specification (called product information sheet on the originating web page BP Ultimate Diesel | BP Retail Australia , as currently available from BP website (Issued : 1st May 2010) claims a cetane index of min 46, typically 52.
    http://www.bp.com/liveassets/bp_inte...ate_Diesel.pdf
    Now I'm confused. Is this the difference between a cetane number and a cetane index or did they change the product specification along the way??
    2015 Polo Comfortline 6M + Driving Comfort Package
    2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
    (2008 MY09 Polo 9N3 TDI retired hurt hail damage)
    Jan 2009
    Cetane number (CN) is a measurement of a fuel's ignition delay.
    Cetane index (CI) is a calculated approximation of a fuel's CN. Most sources tend to agree that it correlates well with CN, but since the calculation is based on the fuel's characteristics, there is debate on whether it also reflects the effects of cetane improvers (additives added at the refinery).
    So for example, say you have untreated fuel (no additives) with a 'baseline' CN of 46. A calculation of the fuel's CI might also net you a result of 46. Once the refinery adds cetane improvers, that might raise the CN by, say, 4 points, so you end up with a final and true CN of 50. However, the CI doesn't change if the calculation doesn't take the effect of additives into account (depending on which study you believe).
    That explains in my example above, why the same fuel has a CN of 50 and a CI of 46.
    BTW, there is no such thing as a 'cetane rating'.
    Sep 2008
    I asked BP, who advised me that BP Ultimate Diesel no longer contains a cetane improver. It used to but it no longer does.
    The current specification for BP Ultimate Diesel is for a minimum cetane of 46, though the typical value is usually around the 52 mark. The BP Ultimate Diesel contains both detergent and antifoam additives but in previous formulations it also contained a cetane improver which it no longer does. The reference to a 50 minimum would have referred to this earlier product formulation and is not current.
    So there, there are no premium diesel products on the market in Australia and nothing that meets the 51CN VAG/EN590 specification for DPF-equipped vehicles.
    Jan 2009
    The European (EN590) and Australian standard for diesel specifies a minimum CI of 46. So the 'natural' or 'baseline' CN of untreated fuel (i.e. prior to additives being mixed at the refinery stage) must be at least 46.
    However, EN590 also specifies a minimum CN of 51 - the Australian standard does not (except for diesel containing biodiesel must have a minimum CN of 51). But there is nothing preventing refineries from producing diesel with a natural CN higher than 46. Given the other specifications listed in the standard, such as the maximum PAH limit of 11%, it may in fact be more cost effective to produce diesel with a naturally high CN. Hence why the typical CI tends to be higher than 46 in practice.
    You will also find that most, if not all European manufacturers have always recommend (as opposed to require - the distinction is important) diesel fuel that conforms to EN590 - irrespective of whether it is equipped with a DPF. The performance of a DPF is significantly dependent on sulphur content, compared to the effect of diesel with a CN of 46 or lower.
    And yes, the maximum sulphur content (10 ppm) is the same here as it is in Europe.
    In any case, since the advent of computer controlled fuel injection, the potential variances in CN we are talking about here are easily compensated for, especially in modern engines where its FIE have grown ever more sophisticated.
    Quote Originally Posted by bluey View Post
    So, there are no premium diesel products on the market in Australia and nothing that meets the 51CN VAG/EN590 specification for DPF-equipped vehicles.
    Nup.
    That said, if the Government suddenly introduced a minimum CN of 51, I suspect the refineries are in a much better position to meet that requirement today, compared to say 9 or 10 years ago.
    Sep 2008
    According to a large manufacturer of 2-EHN Cetane Improver 2-EHN - EURENCO, nitro cetane improvers have significant benefits.
    Furthermore, 2-EHN is not only used to improve the quality of diesel fuel, but also to enhance the performance of diesel engine, allowing:
    - quicker cold startup,
    - diminution of engine startup noise,
    - reduction in engine knock and wear,
    - production of lower pressures resulting in smoother performance,
    - decrease or elimination of carbon build-up on injector nozzles,
    - better fuel economy and engine life.
    So why did BP remove the nitro cetane improver from Ultimate Diesel?????
    Sep 2008
    The paper "Fuel additives and the environment" from the special task force of the ATC (the Technical Committee of Petroleum Additive Manufacturers in Europe) talks about benefits of cetane improvers:
    (b) Purpose
    Whilst cetane number is defined in terms of the ease with which a fuel ignites, cetane quality impacts directly on many aspects of engine performance. Engines operating on fuels with a low cetane number are difficult to start, especially in cold weather, noisy, emit high levels of white smoke and hydrocarbon pollutants at start up, produce less power and consume more fuel. High cetane numbers are therefore desirable. This has been recognised by the European legislators who have raised the minimum cetane number of EN 590 fuel to 51.
    Aromatics conversion to naphthenes and paraffins through high pressure hydrotreating is a way to achieve higher natural cetane. However this process is very expensive and few European refineries have the necessary hardware to do this today. Cetane improver additives offer a more cost effective way to achieve higher cetane numbers. They can also help to improve refinery profitability by allowing more naphthenic crudes to be processed, and a higher percentage of low-value cracked components to be used in diesel blends.
    www.atc-europe.org/showdoc.asp?doc_id=210
    This PhD dissertation from 2009 talks about increased NOx emissions related to 2EHN. That might be what scared off BP. Should be not a problem in modern vehicles with NOx catalysts, but would be a problem in older vehicles. The research paper was problematic in that the study used singular 2EHN additive in a research engine with researcher-determined EGR rates and found evidence of injector fouling which has not been noted elsewhere in the literature, and which also made emissions worse.
    FUEL PROPERTY IMPACT ON A PREMIXED DIESEL COMBUSTION MODE by Andrew M. Ickes
    deepblue.lib.umich.edu/bitstream/2027.42/62369/1/aickes_1.pdf
    Specifically, I was trying to find the results from the study "The Effect of 2-Ethylhexyl Nitrate Cetane Improver on Engine Durability" The Effect of 2-Ethylhexyl Nitrate Cetane Improver on Engine Durability. The Ickes paper mentions the durabilty study finding reduced combustion surface deposits and reduced injector fouling, but that in an old engine without EGR. It is expected than reduced engine noise would be associated with reduced mechanical loadings and therefore some less engine wear.
    Adelaide hills, SA
    Did you include in your search EU6 emissions? Maybe it has something to do with it.
    Some more interesting reading http://www.google.com.au/url?sa=t&rc...AR3-5xqMds34HA
    Jan 2009
    bluey, I think you should use cetane improvers for your cars.
    Sep 2008
    Quote Originally Posted by Diesel_vert View Post
    Have been for years and not planning on stopping. Like Transporter, I use Morey's Diesel Smoke Killer. It's a no brainer to improve cetane, as VAG/EN590 already specify a cetane number higher than available out of the pump. Engine runs quieter. Less visible smoke on heavy acceleration means less particles clogging up the DPF.
    BTW, US EPA study 2003 predicts reduced NOx emissions of 2% for improving cetane (modelled 5 points) in truck engines [EP A420-R-03-002 February 2003 The Effect of Cetane Number Increase Due to Additives on NOx Emissions from Heavy-Duty Highway Engines - Final Technical Report - full paper online]
    ---------- Post added at 10:08 PM ---------- Previous post was at 12:58 PM ----------
    Here is the reason why BP removed the cetane improver....email from BP:
    - BP removed the cetane improver from Ultimate Diesel because the
    addition of cetane improver at a terminal presents increased risks with
    handling additives that were considered to be unacceptable without major
    infrastructure changes during ongoing hazard assessment reviews at
    terminals.
    So there was no particular problem with the product, only some risk of handling the additive.
    2EHN best practices manual http://www.atc-europe.org/showdoc.asp?doc_id=294 says:
    Self-reactive, energetic substance with a low auto-ignition temperature - when heated above 100degC may undergo a self-accelerating, exothermic decomposition that causes a rapid rise in temperature and pressure. Rupture of storage vessels, containers and equipment should be anticipated when pressure is generated by such thermal decomposition.
    So 2EHN is a greater explosion risk than the fuel at the terminal.
