Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 62
Thread: BP Ultimate Diesel is now in NSW
    Bowral, NSW
    They don't even sell Caltex regular diesel anymore, do they?
    I've not seen it. :/
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Dec 2010
    Helensburgh
    Quote Originally Posted by GippsCC View Post
    (I understand higher turnover fuel stations are, however, the best source of fuel over anything else but so much gets said and really I don't know THAT much about fuel other than you get it out of a pump lol).
    I think that is most peoples perception. I am in the heavy transport industry and we only refuel at very high turnover outlets and have proven the above perception to be dubious at best. I can show you the repair bills for motors going into the hundreds of thousands and which the fuel company involved paid for most of it. The fuel was obtained from multiple outlets which led us to question the belief that high turnover is good. One station sells far more diesel that petrol and our drivers have been threatened with death if they refuel there again and the owner is screaming as he just lost thousands of dollars a month. I don't think anyone knows if it is an advantage to refuel at high turnover stations as there is no way to prove it just gut feeling that it should be so.
    Apr 2012
    They have this at BP Mortdale (NSW), Ill be filling up tonight with it to check it out.
    I hope its a notable difference like Ultimate 98 is!
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Ozsko View Post
    Any diesel bulk tank installation should have a basket pre-strainer, a final filter and a water separator as part of the system before it is pumped into your tank.
    The problem with diesel in particular is that there is a lot of substitution that takes place, and it is not easily detected by the person refuelling. It is not as easy to do substitution with petrol.
    What happened to the little transparent bubble with the flow indicator that you used to see on bowsers? All fuels are specifically coloured, and apart from giving you a visual indication of flow, you were able to verify the colour of what you were putting in your tank. I also seem to recall that there used to be a colour chart so that you could compare colours.
    Apr 2012
    So the price of the Ultimate is the same as their normal blend at my local, also imo when stepping on the gas, the difference between Ultimate & normal is not as notable as the difference between Ultimate 98 & 95.
    I do appear tho to be getting a few more klms than normal. Will confirm that at the end of the tank.
    Apr 2008
    My first tank definitely went further, but had an irregular driving week b/c of Anzac day etc.
    See how it goes overall.
    Doesn't feel faster though.
    May 2009
    Frankston, Vic
    Apart from letting anyone know that the product is available, these threads are completely useless.
    1. Fuel usage is different for everyone.
    2. Every car is slightly different.
    3. No one can tell off the seat of their pants if a car is 'faster' or not because they've used different fuel.
    4. You'd need a PRETTY CONTROLLED dyno environment to convince me otherwise.
    Apr 2012
    Quote Originally Posted by manol View Post
    Negative.. they are guides, not completely useless.
    1: Its either metro or country driving, stop start, or highway kays
    2: Comparing the same models, slightly yes, majorly no
    3: When you have experience, you know what your feeling, especially when those have been driving reflashed & modded cars for years n years. Besides, its not faster that you get, its more torque & pull, once again, experienced folks already know this.
    4: Ive been on 5 different dynos up here, 2 of them give me the same numbers, the other 3 are close but no cigar.
    Bowral, NSW
    Well, I dyno'd mine today and got 135kW/361Nm out of my TDI125.
    Also, took off at a set of lights next to a vRS TSI DSG and he only pulled away once we got to a very decent speed... One that the boys in blue would not like.
    Also have a BSI torque mount insert, but the difference with the BP Prem Diesel is very noticible.
    Every tank now wants to go to 1,000km, too. With city traffic.
    May 2009
    Frankston, Vic
    Quote Originally Posted by Dr freedom View Post
    1. Yes and some people feather their foot around the city and some people absolutely plant it.
    2. Enough that you can't draw any solid/consistent figures, because once again, it relies on point 1.
    3. Don't pull that patronising 'experienced folk' card. 'Feel' is completely subjective, if you filled a car with BP Diesel one time, then with Caltex Vortex and again with Shell Diesel and you did a blind test with an 'experienced' person behind the wheel, I'm willing to bet a lot of money that this 'experienced' person would not be able to tell what fuel was in what car.
    4. Your point proves mine 100% valid.
