Drove home from work (about 50km highway driving) and car started feeling a bit funny last 10km or so, felt less powerful and was holding gears at higher revs than normal (about 500rpm higher).
Anyway started car up about 2 hours after I got home to go out and engine light stayed on. Drove similar to how it was in the last 10km home from work. Only drove it a couple of km then turned it off again.
Put the VCDS on it and this is what it came up with -
Code:
Monday,29,August,2011,21:37:30:27769
VCDS Version: Release 10.6.4
Data version: 20110418
                Address 01: Engine       Labels: Redir Fail!
Control Module Part Number: 03G 906 018 FC    HW: 03G 906 018 FC
  Component and/or Version: R4 2.0l PPD1.2 G    4357
           Software Coding: 0000078
            Work Shop Code: WSC 06441 785 00200
                      VCID: 6BFB151C3315
1 Fault Found:
001139 - Exhaust Pressure Sensor 1 (G450): Signal too High
               P0473 - 006 - Short to Plus - MIL ON
             Freeze Frame:
                    Fault Status: 11100001
                    Fault Priority: 1
                    Fault Frequency: 120
                    Reset counter: 40
                    Mileage: 101333 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:45:10
             Freeze Frame:
                    RPM: 832 /min
                    Torque: 40.0 Nm
                    Speed: 0.0 km/h
                    Voltage: 10.96 V
                    Mileage: 0 km
                    Text:   84    C
                    Pressure: 1001.1 mbar
Readiness: N/A
Anyone know where the exhaust pressure sensor is at so I can check it out. Any other ideas?
