Results 1 to 4 of 4
Thread: BLS Timing - Will this end in tears
    Jul 2007
    Brissy
    I have take my sisters Caddy while she travel around Oz. It broke down a while back and I thought I'd try to revive it.
    VCDS Scan shows Cam Position errors. Engine starts when sensor unplugged only. Throws out of range or implausible signal when connected.
    Bench testing the sensor shows its still working.
    Water pump is leaking badly.
    I decided to check the timing.
    Once the cover is off I see this fluffy crap everywhere. The belt is wearing, does not look good.
    The timing looks to be about 1 tooth out.
    Am I right to think I can adjust this timing, chuck in a new WP, Tensioner & belt and it will be golden ?
    Did the belt breakdown due to the leaking coolant ? or something else ?
    BLS Timing - Will this end in tears-crank-jpg
    BLS Timing - Will this end in tears-fluff-jpg
    BLS Timing - Will this end in tears-belt1-jpg
    BLS Timing - Will this end in tears-belt2-jpg
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Dec 2008
    Sydney/Canberra
    Time it up, put a new belt on, and see what happens.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2007
    Brissy
    Quote Originally Posted by Umai Naa!! View Post
    Thanks
    I ordered the timing belt kit.
    Water pump is proving to be difficult to remove, lots of penetrant sprayed, I will hit it hard when the I get back to it on Saturday.
    MK4 GTI - Sold
    Jul 2007
    Brissy
    SUCCESS !
    New belt, pump, tensioner, idler and mount bolts.
    Fired right up, no codes and it has heaps of power again.
    It is a keeper.
    MK4 GTI - Sold
