Results 11 to 20 of 26
Thread: Blowin' a bit of smoke!
    Mar 2012
    If you have ever seen how much smoke mine blows you'll know it's normal
    Gosford Central Coast NSW
    Pearce - no spark plugs on a diesel engine
    Yes- plenty you can do to up the power, but have a search and read around the forums - its all been discussed at length before.
    Your tuning box works by misinforming the ECU about the qty of air the engine is recieving (or the air temp - same effect anyway) and thus gets the ECU to inject more fuel. This gives you more power on a diesel up to a point, but its a very cheap and nasty way to do it and is also why you have a disproportionate increase in smoke for hte amount of power gained.
    I have a tune on my skoda thats gained me about 20kW and 50Nm and it smokes less than with the standard tune - because the boost, injection timing and fuelling maps have been altered.
    Check out all the stickies for some more diesel reading.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Feb 2013
    Vic, Aust
    Oh god I can't believe I wrote that.
    | Candy White 2007, Mk 5 Golf, 2.0 TDI | 103 kw chipped to 138 kw | 19" Mercedes C6319 Gloss Black | Stage 1 APR Cold Air Intake | DNS-810 GPS Unit (Eventually...) | Diesel Geek Short Shifter |
    Build Thread: http://www.vwwatercooled.com.au/foru...ild-85147.html
    May 2009
    Frankston, Vic
    Get rid of that box.
    Just do it, they're awful. Get a proper tuner onto your car.
    Apr 2008
    What he said.
    Apr 2012
    Victoria, S/E
    Hey mate, I want to do my EGR soon, maybe organise to do it some weekend together?
    Hennessy Auto Styling MK5 TDI [SIZE=3]|| United Grey || Sunroof & Leather || 18x8.5 +45 Rotiform BLQ and 17x8 17x9 +39 Stern Reverse Face II || K Sport Deluxe Air Suspension || After Market OEM Style Body Kit and Accessories!
    Hennessy Auto Styling - Bumpers, Spoilers, Carbon, Lips and more.
    Feb 2013
    Vic, Aust
    Haha yeah sounds like a plan. I have a couple of friends that will help so see how we go. I'll let you know!
    Apr 2012
    Victoria, S/E
    Hey man I went ahead and bought the darkside developments Egr delete.
    And have since installed it, (was a pain to remove the Egr and fit new one mostly die to the Egr cooler pipe being in the way, and I have fat hands haha)
    But warning, if you do this you will get a engine light "emissions garage" which is caused by the removal of the original Egr which has a flap inside too a straight pipe from dark side.
    But I have been told that with a tune this can be tuned out.
    My car has 992xx Kms and was pretty filthy. I didn't remove my inlet due to lack of daylight but I cleaned with about 4 rags as far as I could while It was still on.
    It is worth doing but make sure you have Allen keys that are under 4-5 inches in lenth (I hade longer ones around 6inch and it just made everything a real pain in the ass!)
    Dec 2009
    Kew, VIC
    Quote Originally Posted by lhennessy View Post
    Haven't had occasion to look at one, but in a tight spot I've found the best way is often to cut a short length off an Allen key, then use a socket and ratchet (or a ratchet spanner.)
    Apr 2008
    When I did it, I found that it was actually a T27 or T28 bit, not T25 or T30.
    Made a big difference
