Straight swap, VW moved to nylon inlets to both lower costs and drop heat transfer. You sure the 2009 engine is still PD MKV?? Can you post pic of top?
Had the turbo blow in my Late 2006 MKV TDI last week.
Sourced a low k BKD engine from a 02/2009 MKV so was just going to do a complete engine swap.
So the engine turns up this morning but the inlet manifold is the plastic type, mine has the alloy type.
Just wondering if anyone knows if it is a straight bolt in with the plastic manifold or
if I need to swap them?
Thanks,
Andy
MKV Sportsline Soot Belcher
MKV Jetta FSI DSG
Hey Greg,
yeah it's a PD engine.
Sorry for the confusion, the car was complied 02/2009 but was built 05/2008.
Thanks for confirming it's a straight bolt in.
Andy
MKV Jetta FSI DSG
how many km on your old engine mate?
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
around 198,000.
engine is fine and I have never had a problem with it other then the turbo going.
I was going to just get a new turbo but I got this engine with turbo, DMF (which was starting to go) so I'll just replace the lot.
Anyone close to Lake Macquarie/Newcastle have a BKD cam locking kit for a timing belt change?
MKV Jetta FSI DSG
I do, but not close, so happy to be plan B.
My turbo went also at 192k. I have the same engine. Whacked another turbs and intercooler on there and good as gold. I was going to go down your route with replacement engine but until something breaks internally, I figured there was just no point throwing $ away.
Sent from my Redmi Note 2 using Tapatalk
2007 Golf MKV 2.0 TDI DSG | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
I've got the tools. I'm local too....not sure but I think my dad has borrowed them though - when do you need em?
'99 A4 Quattro 1.8T
MKV Jetta FSI DSG
