Yeah thats right, pretty good I reckon, hmmm maybe long range tanks......
So about 3.85L/100 then if I've got it right? That is quite impressive!
'04 BMP MkIV R32 #144
search getnew
BMW E36 M3 3.0L LTW - SZYBKI
VW Up! 1.0L - WGN WERKS
I filled the Eos on Christmas Eve to check the fuel consumption for the first time [MY09 TDI common rail DSG].
Distance travelled: 815 Km
Fuel used: 46.2 litres
Fuel consumption [metric]: 5.67L/100km or 17.64Km/litre
Fuel consumption [imperial]: 49.8mpg [imperial gallon]
41.5mpg [US gallon]
This was achieved with a mix of 80% country, 20% city driving with the A/Con on for about 50% of the time [the roof was down the other 50% - the car is the best drought-breaker ever, plan to take it out and it will rain every time]. Best instantaneous fuel usage figure on the trip computer observed so far is 4.1 L/100Km at constant 80 km/hr for 20Km due to roadworks [A/c on]. The effect of the airconditioning system appears to be around 0.2 L/100Km extra at speeds in the range 80/115 Km/hr.
Very impressive and will get better as the engine frees up [2400Km on clock so far] - diesel technology improvements now make the TDI a worthy alternative to be considered.
Carer for my partner's Eos 2.0 TDI DSG MY09 Candy White/Cornsilk Beige leather trim.
not not quite, actually- Transporter is 100% correct - there is actually no fuel being injected when on the over-run ie the momentum of the car is keeping the engine turning over. So when the MFD says 0.0 l/100km it is exactly that. The injectors will start injecting fuel again when the engine is approaching idle speed to stop it stalling.
So if you time your run right you can back off as you approach a red light, and you are using no fuel whatsoever on the run up to the light. This helps fuel economy.
There are some that debate that if you lift off too soon you have to your foot on the accelerator again to stop slowing down too soon and this uses more fuel than putting your car into neutral and coasting in with the engine idling, and the even more extreme will switch their engine off (but I think that is crazy stuff, and totally inappropriate for driving on public roads).
this is the best i've gotten from a tank. it was 90% highway and average speed probably 110. the other 10% was fanging it through melbourne lol.
2x Caddy, 1x Ducato
