Results 1 to 6 of 6
Thread: best diesel
    Jan 2006
    Canberra
    best diesel
    what is the best newish diesel to put in my mk1?? would any of the t4's (2.5turbo) fit?? is it hard to fit? I have heard about the new mk5 tdi's requiring oil that cost $30/litre so not interested in that. What other turbo diesels fit?? My other option is to throw fuel economy out the door and put a 12a rotary in it.
    Cheers.
    Ian.
    \'59 beetle, \'60 Beetle and now a \'77 Golf 4 door.
    I\'m a goin\' HARDCORE!!!!
    imported_brackie Guest
    Re: best diesel
    Quote Originally Posted by Hydrophobic
    From what I have read, all diesel blocks will bolt up. If you are fitting a late model Tdi motor you will need all plumbing, computer and exhaust manifold/turbo. I've investigated importing a 1.9 Tdi and 5 speed (yes, the gearboxes have different ratios) form Europe and it will cost ~ $1k in freight plus government charges.
    Not sure about the external dimensions. The 5 cyl certainly wouldn't!
    Balance it out. It's synthetic oil so the change interval is much longer. It works out pretty close to using a good quality mineral oil.
    None that I know of. Most people fit Golf diesels to other makes, not the other way round!
    Don't you dare!!!!
    Cheers.
    Ian.
    If you like a challenge then go the TDi route, however it's much simpler to use an engine with a mechanical fuel pump. I had an 82 Mk1 GTD 2 door with a 1.9 litre that originated from a transporter, plus a bigger turbo & an intercooler...
    Try Golf Loon, he's probably got something in that famous shed of his!
    Camden, Sydney
    Yeah thanks Peter.
    I have a 1.9 Diesel Engine and 5 speed from a late Golf 2. Not turbo, but complete and gagging to convert your 1.5.
    Steal it from me for $1000
    Straight in
    1.9 and 5 speed should slot straight it. You'll have to change the gear linkage and perhaps the clutch from manual to hydraulic depending on what the gearbox came out of.
    Camden, Sydney
    Gearbox is cable clutch. Your Mk1 cable will match straight up.
    Gearlinkages need to be swopped over and engine mounts. Thats it.
Similar Threads
  1. Running in a new diesel
    By brackie in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 30-01-2009, 10:29 PM
  2. Petrol or Diesel
    By denilu in forum Mk5 Golf & Jetta
    Last Post: 29-03-2007, 10:33 PM
  3. 1.5 diesel Design paper
    By smithy010 in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 13-01-2007, 06:16 AM
  4. Diesel Tacho
    By smithy010 in forum Diesels
    Last Post: 27-08-2006, 11:37 AM
  5. Diesel blowby and runaway... A temporary solution
    By imported_brackie in forum Diesels
    Last Post: 24-06-2005, 10:00 AM
