Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
Thread: Battery life of TDI
    May 2006
    Adelaide South Australia
    Quote Originally Posted by jdd View Post
    Managed to find the same battery it came with (Varta) for a similar price as the other common brands we have here which all seem to be made in China these days.
    I just received a quote for a Besco brand [Malaysia] DIN 65 LH for $134. The Bosch over here is $219 or $250 for the Premium. I didn't find a price for Varta but I believe it to be similar to Bosch. How much was yours?
    Numerous Mk1 Golf diesels
    Adelaide hills, SA
    Quote Originally Posted by jets View Post
    I can get you BOSCH S5 for your Tiguan for $190 (pick up only)
    May 2006
    I was buying a battery for my tractor when I thought I would get a quote for our BKD Mk5 Golf. The Golf was made in late '05 & was replaced a couple of years ago as a result of our fridge [in the boot] being left on. I replaced it with an Asian battery of some sort but found when fitting it wasn't as tall as the original causing fitting problems. Apparently the correct height batteries are now available. At the time I wasn't aware that the Varta brand was available outside of dealerships. Through this forum & asking questions I now know there are quality batteries available in the Bosch & Varta brands. The next replacement will probably be in our T4 where I will be looking for something better quality than the Asian one I fitted.
    Dec 2006
    Kilsyth, VIC
    I expect that there will be a few more failures in the coming few weeks. Batteries that are on the edge tend to fail when it gets cold. The first real cold snap overnight will bring a busy morning for the NRMA/RACQ/RACV etc.
    Feb 2014
    Central Vic
    If always thought that Yuasa were a good Asian brand.
    We had one that lasted from 1976 to 1986 in the first version of the Honda Accord.
    how they are handled pre sale is important IMO.
    Never use terminal straps to carry/install as that is likely to break the gas seal twixt case and terminal leading to permanent corrosion problems.
    May 2006
    Quote Originally Posted by Ryeman View Post
    Good point. Most of the batteries I have bought have had handles built in.
    Feb 2014
    Central Vic
    Yeah, it's a very old way that's been fixed by the manufacturers these days.
    Erskineville, NSW
    Yuasa are great. Good luck trying to buy a Yuasa automotive battery in Australia though (they only seem to bring in motorcycle/jetski batteries). Ditto Panasonic.
    Isn't Yuasa American?
    Feb 2014
    Central Vic
    Pretty sure it's Japanese unless the yanks bought them out. The 1976 Accord would have been all Japanese I think.
    I noticed them at Battery World the other day but not sure if they are only cycle/marine only.
    May 2014
    central, Vic
    I deal a lot in gel /agm batteries in my job so get to play with 100s of top quality batteries. I don't believe any gel battery will out last or survive as long as a wet ( flooded) battery when mounted in the engine bay. The heat and resulting in correct charging voltage kills them in months.
    I also expect cars running start/stop will have different battery life. A good heavy duty battery should last longer and not circum to sulphation. But a cheap battery with thin paste plates may die early from 100s of extra starts a month.
