Results 1 to 10 of 12
Thread: B20 & B100
    Jul 2005
    Newcastle, NSW
    Welcome firstly!
    And there is going to be lots of opinion from people - but there is some information that has been discussed here!
    Jan 2007
    South Australia
    Welcome to VWwA David
    DutchAussie (Arie) has some biodiesel experience he should be able to help you.
    I think VGA's Official line is No to Biodiesel as it hasn't been tested here yet and homemade quality is unknown so VGA don't want to risk it.
    Also you should know some Diesel fuel has B10 I think as the government approve it, so that should be ok.
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Jul 2007
    Blackburn South VIC
    Thanks for the replies guys.
    This was the official responce:
    Dear Mr XX
    Thank you for contacting us through the Volkswagen Australia Website.
    In regards to your email, Volkswagen does not recommend running their vehicles on biodiesel.
    European Vehicles are specifically ordered from the Volkswagen Factory for the use of Biodiesel fuels. These vehicles are not available to Australia as our Biodiesel fuel quality differs from European fuels. Damage can occur to rubber hoses, seals and other components and therefore are unable to guarantee the longevity of any affected components.
    Volkswagen understands our customers are enviromentally and/or financially conscious and are working on a satisfactory outcome as interest increases for this fuel.
    I must advise that if it was to be found that any part has failed from the use of biodiesel it would not be covered by your vehicle warranty.
    Kind Regards,
    Volkswagen Customer Assistance.
    www.volkswagen.com.au
    02 9273 2725
    A fairly lame reply given that i asked for some idea of what modifications were needed to run biodiesel. Will chase up some more and post answers
    Regards
    David
    brackie Guest
    Biodiesel in Oz
    I'm a bit reluctant to get into this discussion because it's a highly opinionated subject and really, nobody has the answer.
    However:
    Yes, biodiesel is a powerful cleaner and will definitely scour out anything loose, corroded or perished in your fuel system.
    No, if your car is new(ish) then there's no problem as none of the areas described above are relevant.
    Yes, VW and other manufacturers say that the Euro-compliant diesels are designed to use BD while those that are exported to Oz aren't. What exactly they do to make them compliant is unknown to me
    Commercial BD in Oz has to comply to our standards (there are 2 guys on this forum who are a full bottle on this...maybe they can contribute).
    BD smells and you can't mistake it. If you were to take you car to be fixed under warranty Blind Freddy would know that you've been running on BD.
    Unless you have a properly engineered, 100% safe manufacturing process and you have efficient filtration you're putting your injection system at risk running on home made BD.
    Like brake fluid, BD is to a small extent hygroscopic (it absorbs water) so a water dropper may help but cannot remove all of the water. Water is the worst enemy of injection pumps and injectors. It's a good idea to install a dropper like below.
    I've run some of my diesels (but not my TDI) on virgin canola with success. A few years ago I bought a Pug 505 from the mainland that had been running on home made BD for a couple of years. The fuel system was a mess (below is a pic of the filter and it's contents when I first changed it. I had to do this frequently!) And the fuel tank had to be replaced because the water in the fuel had eaten through it. I also had to replace some of the steel and rubber fuel lines.
    So I'm not putting BD down, we all should be using it, however it needs to be made and stored properly and everyone should be aware of the potential problems of using it in an old car.
    Jul 2007
    reservoir, vic
    Have a look at the biofuels forum. There are people there running various new VW's (and many others cars) on bio from commercial sources. I'm not sure where you are but you can look at the "biodiesel finder" on this site which will direct you to places to buy it all over Aus.
    While I'm not an authority on biodiesel, it seems that newer cars should deal with it fine provided its not really cold and the bio is good quality. Especially if it is only B20. However, any blend above that is when the cleaning of the tank, extra filtration and warming in cold climates becomes an issue.
    I'd recommend anyone interested in bio look at this forum and read up on peoples experiences with it. There seems to be much misinformation when it comes to its use in Aus and real world examples described on the forum are more useful than the stuff trotted out by car manufacturers.
    Cheers, iain.
    Jul 2006
    South Australia
    Quote Originally Posted by brackie View Post
    Brackie,
    thanks for your comments and pictures.
    I am very interested in the filter and water separator in your picture.
    Are they on your car?
    If so could we have some details, e.g: make and number.
    Regards,
    Arie
    Australian VW Caddy Forum
    http://www.getphpbb.com/phpbb/index....um=dutchaussie
    Australian VW Caddy Website
    http://VW-Caddy.yolasite.com
    Nov 2007
    The Land of Oz
    Alternatives
    G'day, mate.
    Brackie doesn't post here any more however I may be able to help.
    The filter/water dropper fitted to the Mk1 Golf diesel was OK but had three disadvantages:
    1. it had a small capacity
    2. there was no "glass" to enable you to see any water present
    3. it was expensive.....
    however as long as you are a regular under the bonnet it took only a few seconds to drain any water out of it.
    The filter arrangement in the pic is a CAV and could be done by using the filter/dropper from a Pug 504 or 505 and an extra filter from just about any industrial application. A good place to look would be a tractor or industrial machinery wrecker. All of my (3) tractors have dual filters of exactly this type. The filter elements are very cheap and it's a breeze to change them.
    If you intend running on canola or b100 then it's essential to have an efficient arrangement and to change filters often especially in the first few months of operation when the bio is "scouring" the system. A mesh prefilter to take out any big bits first is also useful. Mercs have these. Another thing not to neglect is if you are using home made bio and have a steel tank you should drop any water out of it regularly.
    Jul 2006
    South Australia
    Quote Originally Posted by cetane View Post
    G'day, mate.
    Cetane (very good name!),
    thanks for the reply. I have been looking at American sites for filters and yes, they are very expensive. I will try and find a truck or tractor wrecker.
    I don't store my Biodiesel. It goes into the VW Caddy as soon as it is made and I keep the Caddy tank full at all times.
    The Caddy has a "plastic" fuel tank. I don't know what kind of "plastic"it is made of. I presume it is HDPE. Do any of the members know?
    Jul 2006
    South Australia
    Biodiesel
    Quote Originally Posted by phaeton View Post
    David,
    come and visit my Website and Australian VW Caddy Forum or send me a Private email about Biodiesel and the VW 1.9 L TDI Engine performance.
