Page 1 of 10 123 ... LastLast
Results 1 to 10 of 100
Thread: anthony--t mk5
    Mar 2012
    Central Coast, NSW
    anthony--t mk5
    Wasn’t going to make a thread for this car but thought it might be a good diary and somewhere I can ask questions to you guys if I need to.
    My step dad decided it was time he offloaded his mk5 golf and get into something a little bigger (passat). Wanting to keep the car in the family as he bought it new in 2008 he offered it to me at quite a reasonable price. Car has done 217,000kms but I knew it'd always been looked after and never had any problems so after owning a fair share of mk3s (and a mk2 briefly) I took him up on the offer and committed to moving on my mk3 and upgrading to something a little more modern, comfortable and reliable. Knowing there was a few things I would want to change on the car I started purchasing some bits and pieces for it.
    Soon after this decision was made to buy the car we encountered it's first ever engine problem (running rough, down on power, very tappy
    sounding) so we took it to the mechanic that had been servicing it for the last few years and he refused to touch it so off to VW for a
    diagnosis. No fault codes so they wanted to take the head off to inspect as they suspected it was an intake valve causing the problem.
    I doubted that was the issue and there was no way we were prepared to pay the labour costs on that so took it to another local mechanic. He
    suggested it was the injectors and roughly quoted $2500 plus labour to replace them. After we questioned him with no guarantee on his work we decided to take the car back home and think about it. After the thousands of dollars quoted to fix the car my step dad renegotiated
    price with me to take the car as is so he didn't have to deal with getting it fixed. Meanwhile I had found a used 1.9tdi motor on eBay
    for a fair price in Canberra so contacted the seller and arranged to pick it up on the way home from VITS in Albury thinking I could use
    the injectors out of it or if necessary swap the engines.
    Having not dealt with diesels before and not having had a whole lot to do with engines anyway I asked Aydan (GldGti) for some advice and he
    doesn't live too far away from me so he came around one Sunday to have a look and see what he thought. In this time I had been researching a lot and come across problems some of the pd engines have with camshafts (mainly overseas). Symptoms seemed similar and soon enough
    after a quick trip to Bunnings to buy some tools (mk3s don't use torx bits) Aydan and I pulled the rocker cover and inspected the camshafts
    to note 1 had worn out significantly. Aydan offered assistance in changing it and suggested doing the timing belt and water pump while
    at it for piece of mind so currently waiting on parts to do that. I’d like to thank Aydan for his help and for his help in advance for when
    we fix it.
    That pretty much brings things up to speed. I’ve just been installing all my parts that I had piled up in my room for months.
    My mk3 vr6 that I had to let go of to get into the mk5.
    Mk5 as I bought it. Completely original mk5 1.9tdi trendline BXE engine code.
    Installed some fk streetline coilovers bought second hand off a forum member here. I removed the front helpers, cut the bump stops in half
    front and rear and removed a rear locking collar before install to save me pulling them out again. Also cut the screw tab in the inner front arches and rolled them and trimmed the fender linings front and rear.
    Also pre ordered engine mount spacers from Euro-Image tuning for it. Hopefully they’ll get made up as I plan to lower this a bit and want
    to avoid cracked sumps. (Changed a few on my vr6)
    After install the car sits pretty much dead even at 24" in each corner (fluked that). It's on some 16" stock wheels which I'll be changing
    for some 17s that I had bought for the mk3 and probably drop it at least 1" to 23"
    Installed a 2nd hand ANS-510 (Rns510 copy) that I bought off a facebook group. Just wanted something I could plug a phone into and this was cheap (relative to VW and aftermarket units) has all sorts of fancy navigation features, touch screen, plays dvds etc. Was going to install a sub but it sounds so good as it is I'm not going to bother! (Compared to mk3 stereos). Also chucked a stubby aerial on that I had
    around.
    Installed front and rear GTI seats that I won on eBay. Good opportunity to vacuum it out and collect some dropped coins! (Don't have a pic of them in the car)
    Plans are to fix the camshaft and just drive the thing! Will give it a good detail and muck around with wheels a bit but apart from that pretty happy with it as it is after my little changes.
    What a lengthy post… I’m procrastinating TAFE assignments.
    Jun 2007
    Eastern Suburbs Melbourne
    Buys new can for comfort, slams the shiznit out of it anyways... LOL.
    Cool, it does look to be a fair bit more.. Trendier.. than the mk 3... ahhh........
    i like volkswagens
    Mar 2012
    Central Coast, NSW
    Jrad. This is my swamp and I'll #lowerit if I want to.
    Trendier. I see what you did there. Punny bugger.
    Jun 2007
    Going for a shrek/love motif too then? haha
    Can't wait to see what wheels you throw on
    i like volkswagens
    Gosford Central Coast NSW
    Glad to see youre sharing the tdi love! Will be good to get it running with the new cam.
    At least it should still be more comfortable than the mk3 when slammed.
    Sent from my HTC Incredible S using Tapatalk
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Mar 2012
    Central Coast, NSW
    Can't wait to get that cam sorted and be driving it around! (Timing belt kit should arrive next week.) Will be much nicer than the rodeo I've been borrowing in the mean time.
    I only feel that it is moderately lowered. There is at least another inch or so of thread left in the coils
    Have to see how they settle after a test drive (can't do until motor is fixed)
    haha - slammed golf is definitely more comfortable than a rodeo.... although a rodeo fully loaded is a pretty smooth ride.
    '99 A4 Quattro 1.8T
    Mar 2012
    Central Coast, NSW
    Finally got my timing belt kit a few days ago after heavy delays on postage. Today gldgti came over so we could get that swapped and the camshaft in. Not being careful enough I accidentally loosened off the head bolts instead of the camshaft bolts... After a quick chat the decision was made that we had to remove the head and replace the head gasket and bolts as the seal was broken. A few hours later and a few colourful words. Turbo off. Head off. Learnt a heap about the mk5 1.9tdi throughout the process. Can't wait to put it back together. Will probably do a few little things in the process. (Egr and maybe asv delete)
    Jun 2007
    lol, whoopsies right?
    i like volkswagens
    whoopsies indeed
    on the bright side, atleast there are no mysteries left in this engine
    '99 A4 Quattro 1.8T
