Page 7 of 18 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 179
Thread: allroad V6 TDI slow build
  1. #61
    Jan 2008
    Sunshine Coast
    Nice to hear you are leaving the cat in, that's the way forward, responsible performance!
  2. #62
    Feb 2014
    Central Vic
    Do you mean play you exhaust sound on your stereo? Not sure I would want that. Perhaps noise cancelling though, that might be better.
    Yeah,
    it'd play on a frequency which you could tune in and select whenever.
  3. #63
    Gosford Central Coast NSW
    Got 870 off km off the first full tank after the new exhaust, which speaks well for the benefits indeed (previously getting 770-800).
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  4. #64
    Having some other issues with the air suspension now, looks like the compressor needs some TLC. I have ordered at compressor repair kit (£29) so will see how that goes. Towed my my 600kg trailer with about 800kg of scaffolding in it on the weekend and the car didn't even seem to notice the load. Even better for reversing said load up my steel driveway. Gotta love quattro auto for that!
    '99 A4 Quattro 1.8T
  5. #65
    Pulled the compressor last night and dismantled it. A bit of piston ring wear but it all looked pretty good considering 240,000km - certainly a new ring will help though. My main concern is that it appears the compressor motor might be the real problem, I suspect worn brushes as I couldnt measure any continuity across the terminals for the motor (at times). I put it all back together and got it to work with some jumper leads, blew plenty of air which was good but its definitely a bit hit and miss with the current as once it was back in the car and working again it stopped a couple of times and started again when I gave it a whack with my hand.... so im even more certain about it being brushes now. Good news is that its not the airbags, no leaks I can find anywhere and the valving is working exactly as designed.
    took about 10min to remove the compressor, 10min to disassemble and 15 min to put it all back, so its not a pain regardless.
    '99 A4 Quattro 1.8T
  6. #66
    Mar 2012
    Central Coast, NSW
    Possible to upgrade the comp to a viair model? I'm really interested in the air setups on these, I'll have to have a google about the setup when I get a chance.
  7. #67
    Welcome to come and take a look man
    '99 A4 Quattro 1.8T
  8. #68
    Mar 2012
    Central Coast, NSW
    We'll have to tee something up. Keen to come see your exhaust too and I think I still have your oil catch tub thing haha
  9. #69
    maybe you should come and give me a hand when I put the resonators in? I'm gonna do that at home cost its not too much welding.
    '99 A4 Quattro 1.8T
  10. #70
    Mar 2012
    Central Coast, NSW
    Yeah man, flick me a message beforehand and so long as I'm not working would love to!
