Page 14 of 18 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 179
Thread: allroad V6 TDI slow build
  1. #131
    Gosford Central Coast NSW
    So, its been a LONG time between updates here....doesnt mean i've been idle though!
    I decided after a fair bit of research that paying for an aftermarket tune, anything more than stage 1 would be a big investment - and since I've swapped the turbo for a bigger one already, it would mean stage 1 would be like the minimum I would be happy with. Most tuners offer a stage 1 for this engine of about +35hp and 50Nm. But because of my new turbo, it would be a lot if iterations in tuning etc....
    So I've decided to tune it myself.
    How? What? Well theres a lot of places you can start, but basically the word around the net is 'dont bother self tuning unless you are prepared to do a lot of work, learing, etc, and it probably wont be cheaper blah blah blah.
    So yeah, thats where I'm up to.
    So far, I have tooled up with a cheap cable from ebay ($22) and MPPS software to read and write via the OBDII port. I have successfully done this on several occasions already.
    I have been using winOLS demo version to analyse my ECU dump and I have been following the numerous winols and various chip tuning forums/guides in order to learn how to identify and interpret maps within the ECU dump.
    I have been using a free bit of software called vagsuite EDC15P (developed specifically for tuning EDC-15 pump Duse diesels) to actually modify the maps I have identified in winols and verify the checksums before writing the modified file back to my ECU (vagsuite doesnt correctly automatically identify my particular ECU's maps as my engine is not PD).
    So far, I have only modified the N75 control map, which is used to provide transient control setpoints for the N75 valve. I have started here for a couple of reasons - first, because before I start trying to make more power, I want to ensure my boost control is as good as it can be. Second, because in the particular case of my engine/ECU (the 2.5 V6 TDI), modifying beyond a moderate fuelling increase is a bit tricky and I havent figured out how to do it yet!
    I have been doing lots and lots and lots of logging using VCDS, basically just of group 11 (specified and actual boost, and N75 duty cycle) and making both mechanical and software adjustments to try and improve the spool and minimise boost overshoot. I think I'm getting to a point where I'll be happy to start increasing fuellign and boost soon, and all of the other required modding that goes along with that (torque limiters, gear dependant limiters, etc etc etc.
    The fuelling increase problem particualr to my ECU / engine is an interesting one, and it will be interesting to see what happens, whether I am amble to get where I want to be or not. As far as I have been able to research so far - all over the internet there is this idea that the VP44 (thats my injector pump) controlled 2.5 TDI is limited in injection quantity by the pump software - however, when you dig a little deeper, it seems that this may not actually be the case, and infact it may be that there are 'single value' injection quantity limiters in the ECU file which are just difficult to identify.
    If the former is true, it means tuning beyond 'stage 1' means getting a bit more creative with hardware mods etc. But if the latter is true, its theoretically a matter of my time and patience in analysing the data to find these limiters, and testing the results.
    Anyway, we shall see what happens!
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  2. #132
    Jan 2008
    Sunshine Coast
    Hey ol mate, good for you. Funnily enough winOLS is what my overseas provider uses to do their tunes, and they are WAY better than the old ones I used to get, which were just % increases in boost, fuel and timing etc. They worked pretty well, but the power of open source is astonishing. A lot of companies still tune via the % increase method, winOLS is the way forward. That said I know RDT here have a LOT of additional software they had to buy, to do specific things, but it is amazing what you can get out of doing an indepth of a set parameter. I had no idea even just the throttle map, which is usually tweaked "a bit" in most tunes, when done in depth with specific software just for that, well the difference is amazing in just that alone.
    So good for you for giving it a go, and I have no doubt you will end up a guru going that indepth. Also if you take the time you can write an amazing tune, thing is it's generally not worthwhile spending that long on each and every car from a commercial tuners perspective. I've had several different tunes on my car now, and when the programmers really spend the time, my god they can get insane results.
    So shall you no doubt!!
    Hey and don't worry about lengthy updates, I've been back on here a handful of times this year and noticed the diesel section quite dead outside dieselgate, but I too have been busy, just not on here as much to post. Have decided to change that, and have stopped doing business work on weekends and have made sure I get back to tinkering, which is the whole point anyway!
  3. #133
    May 2012
    Perth, WA
    Good to see this is still going
    Waiting to see some great results
    I'm also looking to tune my PD100 Polo myself in the future (if I have the time to study how that works)
    The tune I got from my current tuner still need a few tweaks and he just decided to not to respond
    06 Polo TDi
  4. #134
    your in luck with your polo mate, if I guess correctly you should have an EDC15P and you should be able to use vagsuite to tune it. Its a really user friendly program and made just for early PD cars, thats it! You can even enable launch control
    Thanks for your comments Greg. I am pretty happy with the decision over all, as I said I've already learned a lot and I haven't even really tried anything much yet.
    I am pretty happy with where my boost control is at at the moment. I've been doing 'back to back' logs on the way home from work this week and I have today's and yesterdays here for your interest:
    I've tried to align the axes so that you can compare the 3rd gear pull towards the end of each graph. So each one is a log of rpm, boost spec, boost actual and n75 duty cycle (multiplied by 10 so its easier to see against the other numbers.)
    The lower graph is yesterdays, which is where the actuator rod was set up then. Last night after looking over that graph I decided I could go another turn shorter, theoretically improving spool some more.
    What you can kind of see from the graph, and what you can see in the data, is that yesterday, it took about 4.1 seconds to get from 1310mbar to the specified boost 2301mbar, and today it took about 3.5 seconds to get from 1222mbar to 2301mbar. Both pulls were on the same road, with the same conditions, time of day etc, even ambient temp is within a few degrees.
    It also kind of looks like the big slope of the rpm plot is a little steeper from today, so perhaps the engine is making a bit more power with this setting (i.e. accelerating faster with the same load).
    I'm also glad to see that the N75 is able to regulate boost properly all the way to redline.
    I have been having some pretty bad boost control issues, which I have basically managed to figure were due to me using too small a lever arm on the vane control, which made it too sensitive for the control system to actuate properly. I have 2 ball sockets I can clip my actuator onto on the little lever arm on the turbo, 1 I welded on and 1 which was stock. The 1 I welded on I thought I needed because I cant quite get the full range of motion from my actuator and the outer lever, however when I have tried using the inner one, which gives me the full range of motion, its too powerful and I get big spikes on the plot, and the car is actually slower - I fear because it closes the vanes too much when you try and accelerate hard, and it builds up heaps of EMP, then it spikes over the requested boost, opens the vanes, the car surges forward as all the EMP rushes out, and boost drops back below specified, and it all happens over and over again. Terrible!
    With it how it is now, you can see the N75 and actuator are able to do a reasonable job of regulating the boost. Certainly it drives better, I'm not getting lots of nasty surging going on which is probably a good thing for my engine and turbo.
    '99 A4 Quattro 1.8T
  5. #135
    Mar 2012
    Central Coast, NSW
    My eyes glaze over a little when we talk about this and most of it goes straight over my head but keen to see results / lend a hand where I can and attempt to learn something!
  6. #136
    If anyones interested in learning some self tuning stuff, I would recommend the nefmoto forums (good general guides there and lots of 1.8T/2.7TT stuff), ecuconnections.com forums, and also ecuedit.com forums.
    Also theres a great youtube chanell with winOLS tutorials specific to VAG diesels
    '99 A4 Quattro 1.8T
  7. #137
    Flashed a "proper tune" to the car on Friday night. I havent done any logging yet, but if definitely feels different. Changes from the stock map are many - boost target, n75 map, drivers wish, gear limited injection qty, smoke limit maps, EGR maps and more!
    tentatively... success!
    when i say proper tune - i mean one where i mean to gain some power, rather than just what i have done before which was only boost control.
    '99 A4 Quattro 1.8T
  8. #138
    hmm. gearbox... kaput.
    '99 A4 Quattro 1.8T
  9. #139
    Mar 2012
    Central Coast, NSW
    this doing sick skids now or what?
  10. #140
    Quote Originally Posted by anthony--t View Post
    nope, not with blownup gearbox hehe
    Should get it back tomorrow
    '99 A4 Quattro 1.8T
