MK5 PD or MK6 CR?
You won't be able to regen without the EGR flap working effectively, well you can, but it requires some clever driving, not dropping the revs below 2000 at any point while regenning, nor maintaining constant speed, you have to be routinely on the gas as much as possible. It's very difficult to do, but can be done.
DPF not having an error is weird though, my gut feel is you have to sort the EGR flap no question, and get a forced regen happening. Did they adapt the pressure sensor and reset the oil ash levels? There's a bit to do for it to be happy, it's not simple.
You will need to sort the EGR flap, and the fact the workshop or Vag Com person could not force a regen means something is wrong or not hooked up properly, it should do that with the force regen code everytime no question.
