Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Advice after I put petrol in my TDI by accident!!
    Sep 2010
    Newcastle NSW
    Unhappy Advice after I put petrol in my TDI by accident!!
    Distracted and talking to the other driver after a near miss in the service station forecourt, I accidently put petrol in my 2.0 Golf TDi and drove it. After about 3 blocks it shut down and I realised what I had done... aggghhh**$?
    NRMA came and trucked thew car back to the depot. This happened on the Monday after Christmas and nothing is open until Wednesday. The nearest VW dealership is 80 Km away.
    I would appreciate some advice
    1) What sort of damage / repairs can I expect will need doing?
    2) Should Iget the car taken to a VW service centre?
    Regards,
    jettadsg
    Feb 2008
    Richmond, VIC
    It's not a good thing. Probably best to call your insurance company first for advice.
    http://motortorque.askaprice.com/art...-questions.asp
    currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
    previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
    Adelaide hills, SA
    I'm sorry to hear that.
    The no. 2) is the best option. They will also tell you what damage was done. The other alternative would be to drain the fuel system replace fuel filter and put diesel in the tank and see what happens. I would still get the car checked by VW. If you don't have DPF, I would put 1L of Lucas fuel additive to increase lubricity.
    How much petrol did you put in? Did you just top up the tank?
    Jan 2008
    Sunshine Coast
    That's nasty, but I think I'd do what transporter suggets, drain out as much petrol as possible from the fuel tank / lines / injectors, replace with diesel, and pray!
    melbourne
    can you drain the fuel from the tank / pump, cut off the diesel to the engine via a tdiclub-style luqui-moly injector clean (NOT via the tank, but straight outta the can into the fuel feed lines), and curtail the problem that way?
    should i get some links? (as in, i've read a bit about the whole she-bang on tdiclub, with pics etc.... reckon it would help?)
    cheers,
    scotty
    Sep 2008
    Sorry to hear that mate. Wish you the best of luck with the fix and let's hope transports advice saves you plenty of dollars.
    May 2010
    NQ
    Does petrol actually damage or upset the injector pump and injectors? (question for the experts here)
    If not, could you then simply drain the tank, refill with diesel, remove glow plugs and turn the engine over untill all the petrol is 'blown' out?
    Just a suggestion/question to anyone who knows more than me
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Oct 2006
    Albany Creek Brisbane
    Hi Mate
    This happened to me 12 months ago, I got my Mk3 TDi towed to a VW mechanic, they drained the tank replaced the filter and bled the system until diesel was going into the motor. It started up no worries after that...
    I was surprised that not much happened at all to the motor, I was expecting the worst but it is still good today
    Hope this helps
    Sep 2010
    Newcastle NSW
    Followed Transporter's advice. The guys at Motortorque in Grafton drained the tank, replaced the fuel filter, flushed it out and used a lubricating additive in a rich ratio with diesel for a 100k's or so. Its running sweet as a nut and fingers crossed it will continue to. Thanks for the advice guys.
    jettadsg
    Nov 2009
    Wild West
    Great news, good to hear a positive outcome. Hope it continues running well. I too always fear that I might have grabbed the wrong nozzle at the servo, being my first diesel after many petrol cars.
