Results 1 to 10 of 19
Thread: Anyone had G235 EGT sensor fail?
    Oct 2010
    I'm getting an intermittent fault on G235 (scanned with VCDS), the temp sensor before the turbo. Glow plug light comes up and the check engine/workshop message comes up.
    VCDS is reading 1000/1024 degs. Fairly sure this is not the actual temperature but the sensor has failed. Weird though it only happens when I put my foot down, but you can see the other 2 temp sensors aren't going very high.
    So yeah just wondering if anyone has replaced one before. The part number is 03L 906 088 BS and its listed at around $200 in ETKA. I wonder if any other part numbers are compatible.
    Golf GT Sport TDI
    Gosford Central Coast NSW
    I would log the output during a drive to be sure. It should be smooth and vary between 150-200C at warm idle, and getto 3-400 C during normal driving whilst accelerating. During a hard pull I would not want to see it go over 850. If it was really reading 1000C, you would be in major trouble (melted pistons etc).
    They are a resistance based sensor but I would think if it was going to fail it would go way out of range. Also, I'm not sure that it is, but I would expect it to be basically just a k-type thermocouple.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Adelaide hills, SA
    I replaced one last week in Scout TDI BMM engine. I'm sure it's the same sensor, it's quite common failure. Disconnect the sensor’s connector, connect a new sensor or 220ohm resistor and check the measuring block 067, it should be showing ambient temperature.
    Dec 2008
    Northern Suburbs
    I've changed a few, fairly common issue
    Jun 2011
    sydney
    i replace one today. On a caddy.
    Dec 2008
    Sydney/Canberra
    I've put 3 in the same Caddy.
    Not sure what the go was there.
    I did read that you have to be gentle with the wiring, but I was certain that didn't atribute to subsequent failures.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Oct 2010
    Thanks guys, seems like it is very common. Hopefully I only have to replace mine once.
    I have logged it and yeah it jumps up to 1000, I was basically just worried something had gone horribly wrong and it actually was getting that hot.
    I hope its not a pain to get at.
    Golf GT Sport TDI
    Dec 2008
    Sydney/Canberra
    It is a big pain.
    It's buried in amongst the turbo.
    '01 Beetle 2.0
    Oct 2010
    Ah crap. I wonder if I even need it since I no longer have a DPF. I could map the engine light out and save myself $230.
