Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 125
Thread: Adding 2 stroke oil to fuel - Interesting reading!!
    Jan 2009
    brisneyland
    Last edited by benno; 07-08-2009 at 02:04 AM. Reason: leaving the forum due to draconian rules and excessive moderation
    "One art please!" --->http://benno.redbubble.com
    Gosford Central Coast NSW
    i'm going to try it.... i wonder if it makes much difference if you add it to biodiesel
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Canberra
    Quote Originally Posted by benno View Post
    I'd be be a bit cautious if your TDI has a DPF - they are very expensive to replace. VW go to all the trouble of only approving special low-SAPS engine oil in case burnt engine oils contaminate the DPF.
    Dec 2007
    I read as far as page 6, and there was not one single flame post - that's amazing when it can be regrded as a "contentious" issue.
    There is no doubting the lubricity and combustibility of 2 stroke oil - the Rotaxs on our karts pulled 14,000rpm all year on a 50:1 mixture, and the wear was negligible as was the soot inside the combustion chamber.
    I have no doubts that it can replace the lubricity of sulphur in diesel fuel.
    YF's observations about the cleanliness of turbos, etc, makes me idly ponder if adding maybe a 1:500 or 1:1000 mix into the GTI's fuel would keep the air inlets cleaner - they do gather plenty of oil and clog the insides of head ports much faster than a port injected engine.
    I don't think I'll try it, since it's hard to measure any effectiveness in the GTI engine, but if I had a diesel I would definitely check it out.
    2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
    2023 T-ROC R - Sunroof, Black Pack, Beats Audio
    Dec 2007
    Quote Originally Posted by gregozedobe View Post
    There was plenty of commentary about that issue in the small amount I read. YF is specific about the ash content of the 2-T oil recommended, and specifically says not to use fully synthetic in a DPF vehicle because it does what you are fearing.
    Jan 2009
    brisneyland
    Yeah I'm a bit leery of doing anything to upset the DPF. Although the woman (!!!!) who started the thread and recommends adding the oil, is firmly of the opinion that it won't harm the DPF and is in fact protective of it - a cleaner burn leading to less soot in the exhaust.
    Jan 2008
    Sunshine Coast
    F'ing great find, I'm excited about the idea. Bit of research needed, as indeed oil ash clogs that damn DPF, but as soon as I can find a low ash 2 stroke mix, it's in.
    Jun 2006
    Orange NSW
    I'm going to Melbourne tomorrow. Got litres and litres of Castrol R30 at the workshop. I'll throw 300mls in before i leave and see how it goes. I'll also take the bottle with me and fill up on the way home.
    I usually get mid 5's there and back. It'll be interesting to see what difference it makes.
    Report on Monday night.
    Edit: I'm going to use Yamalube as we've got a stack that we'll never use. We tried in in the Karts and there was a definite performance gain in it initially, but the longer you used it, the slower the engine became. This turned out to be because it was actually de-carboning the engine. Removing it from the piston crown and down the sides. This caused more heat soak in the engine and gave less piston seal, which equated to a hotter, slower engine. (Talking air cooleds here...)
    For this application, it should be perfect. The idea is to lubricate and clean, which this stuff does an amazing job of. Anyways, like i said.. I'll get back to you.
    Jan 2008
    Sunshine Coast
    Lucky non DPF types...
    Im keen to try this!
    will get some into the next fill up (or maybe even tonight!!!!)
    should I get just the garden variety stuff thats down at the petrol station?
