DPF offshoot: A lot depends on how you drive it - tramping on the right pedal at low rpm will smoke big time while at higher rpm, when the turbo is pumping lots of air into the combustion chamber, the same action will produce far less (if any) smoke.
Maybe we should get this discussion split into its own thread
It seems less relevant to 2 stroke oil use than 2 stroke oil discussion was in the additive thread
Resident grumpy old fart
