Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 111 to 120 of 125
Thread: Adding 2 stroke oil to fuel - Interesting reading!!
  1. #111
    Jan 2014
    N/A
    That doesn't make any sense really. The mass of deposited carbon in the combustion chamber is very small. If it all got cleaned out at once, which it certainly won't, it would amount to nothing more than a quick puff of muck.
    I've rebuilt enough diesel engines to know what carbon buildup looks like and how and where it builds up.
    The only possible reason I could conceive of for temporary smokyness brought on by some kind of fuel related cleaning, would be that between carbon buildup being baked on and flaking off, it might foul the spray pattern of the injectors... But even that seems to be a stretch.
    As it happens, my Audi only ever really smokes on startup and I note that today it didn't seem to really.
    I agree when you put it that way but i've seen a few posts that mention some blue smoke for a few days when they lift off but it always stops. Maybe it's to do with the rings in the piston grooves and/or the valve guides. Perhaps better cylinder sealing with the 2SO and therefore higher suction on the over-run pulling some oil through until the crud in the ring grooves is cleaned out and the rings can achieve full range again?
    The other aspect is reducing smoking, which you noticed on start up and with a very light mix compared to the usual 1:200.
  2. #112
    Jan 2008
    Sunshine Coast
    DPF's primarily clog because of oil ash. I'd want to run additives that have zero ash personally.
    DPF approved engine oils have amazingly low oil ash levels compared to the norm.
    Still small potatoes compared to the amount of oil blowby stock engines digest.
  3. #113
    Oct 2010
    Melbourne, VIC
    Which is why for DPF equipped cars, you should only use JASO FC or TCW-3 spec 2 stroke oil while those without can also use JASO FB.
    Clearing carbon deposits from the injector nozzles is the other cause for smoke with cars that have been running on "normal" diesel for a long time when they first run with 2 stroke oil. I thought biodiesel users found the same thing.
    Resident grumpy old fart
  4. #114
    Bowral, NSW
    Yours at 15,000km still clean tail pipes indicate that, YES the car's Diesel Particle Filter trap does it's job trapping the unburned oil and extra soot particles.
    My fingers, after wiping the inside of the mid section of the 60,000km-old exhaust pipe of the Octy vRS TDI. (When 3" catback was going in)
    Note: Some of it could also be from the grinder the exhaust shop guys used
    The pipes in question
    (Next to some of the new stuff)
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  5. #115
    Jan 2014
    N/A
    Good job you changed it when you did with all that carbon in there!
    Just finished reading about your car in Auskoda. With a stage 2 tune, intake mods and DPF delete the EGT might have helped clean that pipe out. I hope it's out of warranty or they'll be getting their knickers in a twist in here.
  6. #116
    Gosford Central Coast NSW
    naw he still had a dpf then
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  7. #117
    Jan 2014
    N/A
    If the DPF needs replacing after the warranty runs out it seems a no brainer to give it the flick unless it's something like $300, which I know it wont be. Getting the ECU modified is probably the hard part, especially on Skodas with the locked ECU.
    That rear muffler looks like it could be deleted to save some weight and back pressure and I bet it would still be quiet. That's something that could be done during warranty with little chance it will hamper any claims.
    Sorry, getting off topic.
  8. #118
    Jan 2008
    Sunshine Coast
    Yeah a DPF deleted car is going to pump out a ton of soot, especially on a power tune. Quite obvious these days.
  9. #119
    Jan 2014
    N/A
    Quote Originally Posted by Greg Roles View Post
    Surely their can't be much soot getting through these days, with the injection and combustion so much more efficient?
    If there was, the DPF wouldn't be able to cope.
    I had an ML Triton with the 2.5CRD, the 100kw/318nm version. There was never a hint of smoke or soot from the exhaust.
    I blocked the ERG, had a switch fitted to keep the throttle valve open, modified the exhaust and had the ECU and boost modified on a dyno. It was putting out 131kw/455nm but there was still no hint of smoke or soot from the exhaust and the economy was slightly better than before.
    I did religiously add 2SO at 1:200 to help keep it all well lubricated and clean in there.
    Forgot to mention it did have a cat but no DPF.
    I still have no idea when my 103TDI is doing a regen? What are the symptoms?
  10. #120
    Quote Originally Posted by CardinalSin View Post
    Take it from a few fellas that have cut open DPF casings for whatever reason - DPF equipped engines produce plenty of smoke and the DPF really works.
    FWIW, i see plenty of new diesels (non dpf equipped) that smoke plenty too. It might not be obvious to the guy driving, but its there. New ford territory's and Range-rover sport diesels, I'm looking at you
    '99 A4 Quattro 1.8T
