Which is why for DPF equipped cars, you should only use JASO FC or TCW-3 spec 2 stroke oil while those without can also use JASO FB.
Clearing carbon deposits from the injector nozzles is the other cause for smoke with cars that have been running on "normal" diesel for a long time when they first run with 2 stroke oil. I thought biodiesel users found the same thing.
Resident grumpy old fart
