Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Aargh fuel problem
    Erskineville, NSW
    Quote Originally Posted by Ryeman View Post
    Seeing fuel is always drawn from the bottom of the tank, why is a low level problematic?
    Just guessing - because the algae is floating on top?
    Gosford Central Coast NSW
    algae will hang around closer to the top of the liquid volume for sure.
    Also, any solids that settle out of the liquid will become more highly concentrated as the volume of fuel in the tank is decreased.... its hard to explain in text, but basically when there is lots of fuel in the tank, the probability from moment to moment of the pickup pulling in some solids that are washing around in the bottom is lower than when there is hardly any volume of liquid in the tank, but the amount of solids is pretty much the same.
    I guess another way to put it, is that when the tanks is full, the amount of fuel being taken out by the fuel pickup is relatively small, compared to the available volume of liquid.
    When the avialable volume is very small (tank nearly empty), all the solids are washing around in the remaining fuel, so the concentation is very high, and you are therefore more likely to pull it into the pickup.
    Trust me
    If you've ever tried gold panning, that might help.... maybe
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Feb 2014
    Central Vic
    That would be the case I guess if you weren't in the habit of letting it get low.
    Mostly, if you fill up once you get just into the red (in a VAG car anyway) you usually have at least 7 litres in the tank remaining. I know in the Skoda (which I never ran out of fuel) I could do more than 120km in the red. Same in the cabriolet.
    '99 A4 Quattro 1.8T
    Oct 2005
    SE Queensland Hinterland
    So tank cleaned, actually an easier job than I thought, fuel filtered and put back in, new filter, hard to prime (again), but all good now! There seems to be some agreement out there that the combo of bio and petro diesel can be a problem, plus having the fuel tank low (lots of air).
    Mk3 Golf Tdi about to sell
    Mk 1 Golf GLD somewhere in a paddock!
    Mk1 Golf Cabriolet
    MK2 Golf Turbo diesel engine and 5 sp gearbox
    Sep 2008
    What about a regular algicide-containing additive?
    2015 Polo Comfortline 6M + Driving Comfort Package
    2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
    (2008 MY09 Polo 9N3 TDI retired hurt hail damage)
    Oct 2005
    That's what I am doing now, new mechanic suggested using it monthly, local car parts place says the instructions on the bottle say every tank! I am sticking with the former!
    Mk1 Golf Cabriolet
    Jan 2013
    Preston, VIC
    Quote Originally Posted by sparkie View Post
    Discussion on additives on another thread here too. Goes without saying that the instructions are to use in every tank! Sound financial reasoning from the marketing dep't.
