Results 1 to 4 of 4
Thread: 5 speed and turbo charger for Mk1 diesel
    Oct 2005
    SE Queensland Hinterland
    I've just bought a Mk1 diesel, and I'm wondering what is involved in fitting a 5 speed box and also a turbo. Are they easy to get off a Mk2? Would I have to get parts from Europe? Any ideas gratefully received
    imported_brackie Guest
    Turboing a 1.5D
    G'day and welcome, Sparkie. Nice to see you so enthusiatic about your diesel. We've already talked about putting a turbo on a 1.5 here http://www.vwwatercooled.org.au/vwfo...r=asc&start=15
    As for the 5 speed, the gearing in the diesel box is quite different to that in the petrol box. I've read on other forums that the GTi close ratio boxes do a good job. You would have to bring in a diesel box from the UK or SA or somewhere that used them. We didn't get them here. (Agreed, Syncro??)
    Golfwise Guest
    Diesel gearbox
    A GTI gearbox wouldn't be any good because it doesn't have an overdrive 5th gear (5th is almost the same as 4th on a 4 speed)
    If ypu don't have a lot of hills the wide ratio petrol 5 speed wouldn't hurt.
    Or you could put your diesel crown wheel and p in a normal 5 speed.Not that hard really.
    syncro Guest
    I'd go wide ratio and get lots of mpg.
    Why not bring in a 1.9TDI and 5 speed?
Similar Threads
  1. Running in a new diesel
    By brackie in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 30-01-2009, 10:29 PM
