Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: is 200k's too much?
    Nov 2007
    Thats not too bad mileage for a diesel and the price seems very good to be honest. If well looked after you'd probably get a good 100,000kms more which seems like good value for 10k , so long as you don't have to spend more on repairs. Like mentioned check that the injectors have been replaced but my biggest concern would be if it still has the original DPF. Mine is seriously filled and I've only done about 80,000kms - granted its city driving but at 200,000kms it would be reaching the end of its life and its seriously expensive to replace. EGR would have to have been cleaned a number of times by now too. I cleaned mine at about 40,000kms and it was bad!
    As much as I love my GT if I were in your place I'd probably opt for a non DPF equipped TDI.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    Adelaide hills, SA
    Well, long are gone the times when we used to say that the diesel engine is just run in when it clocked over 100,000km and you're right they should last well over 200,000km. But..........the accessories and the modern fuel system components won't, and it will be an uneconomical to repair it.
    Today's cars just aren't made as solid as the cars made decade(s) ago, and if the first owner didn't take a very good care of it, even cosmetically, ...they look terrible some 3-5 years or so later.
    Feb 2014
    Central Vic
    So true!
    change is happening so fast it's uneconomic for any manufacturer to build for long life as a priority as the public are overwhelmed with choice and not into brand loyalty.
    eg the 2016 Nissan Leaf will have a range of ~300km and fuel cell cars are approaching production.
    so much serious choice......
    as a manufacturer, what to gear up for?
    Bowral, NSW
    Remove dpf, tune to stage two, problem solved.
    My vRS has something like 197,800km on it right now. MY12 model, plenty of life left.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Jan 2008
    Sunshine Coast
    The DPF is the killer. How peeps are approaching 200k without having washed it out or replaced it amazes me, mine died at 120k, but is only now half full at 195k on a max soot tune, my washout has been quite a success.
    My car is running better than ever at 200kms, and I see no need to change it anytime soon. EGR / oil blowby buildup is the other killer with modern diesels, clean that out and things are generally fine. I recently did a rough buildup clean on a mates 3.0 A5 TDI and he thought I had tuned it, went so well.
    The new PD170 injectors are warrantied for a further 7 years, and all cars should have been done by now. I have heard of zero failures to date on the replacements, but for sure it will happen eventually.
    All this said a tune on a 103 puts it bloody close to a 125 tuned, the difference in a straight line is pretty small really.
    A lot of other improvements in the GT over a 103 TDI, but yeah the DPF and gunk buildup in high mileage diesels is always the concern.
