At the end of the day, none of us who advocate adding 2 stroke oil to our diesel fuel will try to force anyone else to do so. But I (and I would expect the others that so so) object to people posting highly speculative potential "issues" that it may cause, especially when a small amount of thought will show how baseless most of this speculation is.
I am happy to accept that there are a few people who have had an issue when running 2 stroke oil in their diesel although I am yet to find a case where the issue was proven to be caused by the 2 stroke oil. This is analogous to someone who doesn't accept the beneficial findings and observations of those of us who do use it but I am not going to brow beat those who have experienced an issue to "prove" to them and others that the 2 stroke oil was not the cause.
I feel the likelyhood of 2 stroke oil being a beneficial additive is very high, given a statistical view of the posts on various forums that I have checked while investigating this practice (much greater numbers of people experience some positive findings vs those with issues), along with my own experiences and those of some people I know. The likelyhood becomes even higher when you consider it is the nature of the internet that people will posts complaints more often than praises.
My position is that it's worth trying - a single dose won't give the greatest benefit to a high mileage diesel but then it won't be enough to trigger any catastrophic event either (not that I believe that it would)
Resident grumpy old fart
