Page 4 of 21 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 205
Thread: 2 stroke oil (2SO) as an additive to diesel fuel
  1. #31
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by CardinalSin View Post
    Those with an EGT gauge report much lower temperatures using 2SO, another indicator of the better combustion and cleaner exhaust.
    Which should lower NOx emissions...
    Resident grumpy old fart
  2. #32
    Jan 2014
    N/A
    Quote Originally Posted by kaanage View Post
    Confirmed by those who have yearly emissions tests. Still no negatives, just positives.
  3. #33
    Gosford Central Coast NSW
    You are reporting on a lot of little tidbits with no references - I mean literally - can you post links to places where you have read such info? Its always good to be able to contextualise information for oneself. One thing that can happen easily on the internet is where you read what someone said someone else did and you pass that on and before you know it the story is 27th hand and fact rather than a first hand observation with context.
    speaking of first hand observations, I have noticed a bit of smoke of late - so not sure if something has changed or not but I'll keep an eye on it.
    I refuelled yesterday and forgot to add any 2SO and have already done 200km, so I might put some in now and see if the smokyness changes at all.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  4. #34
    Oct 2010
    Melbourne, VIC
    Here is a first hand account (admittedly not mine) with the result of the UK MOT Exhaust Opacity Test on a 3 year old car before and after using 2 stroke oil as an additive for about 10 months
    Freel2.com - View topic - 2-stroke oil and diesel
    Is it worth digging up more?
  5. #35
    Jan 2014
    N/A
    Fair comment. I'll see if I can dig up a couple of those EGT posts later.
  6. #36
    thanks for the link kaanage.
    '99 A4 Quattro 1.8T
  7. #37
    Jan 2014
    N/A
    It's hard to find the EGT but i've seen it several times and haven't given up.
    Here's a post that mentions the 'wife test' for an unbiased opinion on the noise reduction.
    I've been adding 2-stroke (Castrol Activ2T) to my 05 Patrol for the last few months and I have definately noticed a difference. I've even done "The wife test".. I didn't use the 2stroke for 2 tanks so the engine went back to its noisy self. I then dosed my next tank without telling the wife, she drive the car the next day and asked what i had done because the car was much quieter...
    Two stroke oil in Diesel - The Shed - Perth4x4
  8. #38
    Jan 2014
    N/A
    Here's one to start with on reduced EGT.
    "I filled both tanks this morning adding 400ml to the main tank and 200ml to the sub. I filled up at Mobil and used their 2 stroke oil for chainsaws etc.
    Have only done a few kilometers, both city and now hwy driving and the car sounds and feels heaps better. Much smoother and quieter. The EGT's on the fwy also appear to be down about 10 to 20 degrees.
    A definate improvement!
    2 stroke oil in your diesel fuel - Page 4 - Patrol 4x4 - Nissan Patrol Forum
    http://www.patrol4x4.com/forum/547249-post365.html
  9. #39
    Jan 2014
    N/A
    Here's another one I found from Sweden.
    Patrol 4x4 - Nissan Patrol Forum - View Single Post - 2 stroke oil in your diesel fuel
    And another one.
  10. #40
    Jan 2014
    N/A
