Back to facts and observations.
I have been using TCW-3 for a while now after starting out with JASO FB (in my PD non-DPF Polo) and FC (in our CR DPF Golf).
Why did I change? Cost - I was able to buy a lot of TCW-3 very cheaply when Shell repackaged their Nautilus outboard oil.
I haven't found any difference between using the JASO and TCW-3 oils.
With noise, it would actually be interesting to measure both the volume and the frequency difference as I suspect that better lubrication may shift the frequency of injector and pump noises downwards rather than altering the volume much as high frequency sounds are often perceived as being louder. But I also suspect that isolating a recording from other noises would be very difficult.
Resident grumpy old fart
