![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
CardinalSin
So would you agree that it's better to use a TC-W3, [semi synthetic, not full synthetic] rather than a Jaso FC with a DPF equipped car?
It's accepted that the 2SO lowers emissions and soot levels from the diesel combustion but I would have thought the ash content of the FC grade, although minimal, would be totally eliminated by using the TC-W3?
Why are there so many threads on the same subject?
While I agree with you on the benefits of 2SO as an additive, I wouldn't say that "It's accepted" since at least one moderator here and on other sites do not believe in the concept.
But to answer your question, I would say that, in theory, you're right in that it's better to use a TC-W3 rather than a JASO FC with a DPF equipped car but in practice, the additional ash levels in JASO FC spec 2SO at 200:1 are so low as to have a negligible effect on DPF loading. The reduced soot due to the more complete combustion will mean that the DPF will have less ash in either case - this is how the Cerium and Platinum based additives help maintain DPFs (if it was just the lower light regen temp, then the same soot would still be produced ash would would still accumulate).
By so many threads, do you mean on different forums?
Reason: grammar
Resident grumpy old fart
