Our everyday ride is a 125kw Skoda Superb, but one of our other vehicles is an 05 F350 7.3 which is used for towing duties. Quite often it sits for 2/3 weeks at a time and I was concerned that the 2stroke would seperate out over that time.
There have been a few tests to see how well it mixes and it appears to bond with diesel, probably because they are so similar both being light oils engineered to combust. I would assume it mixes as well as Caltex and BP diesel do in the same tank.
I always give my chainsaw a good shake up before I start it because i've noticed how 2SO settles out in petrol over time.
I'm sure it wont seperate in diesel but if you're concerned why not mix some in a jar and leave it for a few weeks to see what happens?
Another point might be that in a diesel 2SO is a fuel, unlike when it's used in petrol engines, so the unlikely event of seperation over time would have less if any consequence?
If your diesel engine seats for 2/3 weeks then you have to also think about the other tasks that proper diesel fuel additives do. Like fighting the bacteria, dispersing water from the fuel system making it safe to pass for the delicate surfaces in the modern diesel fuel systems and much more.
None of this is possible with the 2SO.
Thanks, yes I have been using the Chemtec diesel treatment and thought I'd investigate the 2 stroke option before buying the next bottle.
Think I'll give the Moreys a go this time.
A vegetable based one (ie castor oil) will and maybe some synthetics might but a mineral based 2 stroke oil will fully mix with diesel. I add it to jerry cans and there is no sign of separation after a couple of weeks (they're yellow plastic ones so there's plenty of light when you look in the opening.
Really? Can you show me the tests where 2 stroke oil has failed in either of these tasks?
Not that I think it would disperse water (which will lessen the lubricating effect in the fuel pump and injectors so the additive had better increase lubricity to offset this) but it could help with the bacteria (would probably be dependant on the exact oil used) although a test would be needed either way.
Gldgti asked for factual proven statements only - I would have no issue if you had worded your last statement as
None of this is has been proven with the 2SO
Resident grumpy old fart
As a personal, first hand observation, our 103kW CR MkVI Golf used to produce a light soot layer in the tail pipes (I'd wipe them down every now and then while cleaning the car).
Since adding the TCW-3 2 stroke oil at 200:1 during fillups to this car a couple of months ago, the insides of the tail pipes have remained clean. For what it's worth....
Proven at the least by your own personal observations. Since you never run 2 stroke oil, you can't say definitively what it can and can't do.
