Given what Greg Roles has said about flash points and looking at these and auto ignition temperatures of 2 stroke oils (where these could be found), I now feel I was wrong with my previous hypothesis about the action of 2 stroke oil (and other non-metallic catalyst diesel additives) for more complete combustion and smoother running.
The action would appear not to be more controlled ignition but more complete combustion via the extension of the burn interval, since the flash point of 2 stroke oil is pretty much always higher than that of diesel. This would go along with the clean burning requirements of 2 stroke oils (needed to prevent deposits in 2 stroke engines)
Thanks for pointing us in the correct direction, Greg.
Anyone know of a university needing a doctorate thesis topic?
Resident grumpy old fart
