Looking at the Mean Sea-Level Pressure Analysis for the 14th of Feb on the Bureau of Meteorology site suggests that for that region there was southwesterly wind for the whole morning from the high pressure system off the coast (after the cold front that came across around midnight) switching to a southerly as the high pressure system moved further across.
Looking at Cunderdin and Busselton Airport's observations for the confirm this
So most likely headwind/crosswind on the way down, tailwind/crosswind on the way back.
Locals would be best to confirm or deny this
Cleaning off the carbon deposits on the injectors and from the head and piston crown would seem to be the most likely cause for the majority of the economy improvement with some improvement also due to the engine running in more.
Thanks for the additional information, Amalgam
Resident grumpy old fart
