Page 10 of 21 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 205
Thread: 2 stroke oil (2SO) as an additive to diesel fuel
  1. #91
    Adelaide hills, SA
    Quote Originally Posted by kaanage View Post
    Proven at the least by your own personal observations. Since you never run 2 stroke oil, you can't say definitively what it can and can't do.
    You're right, what would I know about the diesels.
  2. #92
    Jan 2014
    N/A
    It's not what you know about diesels, it's what you know about using 2SO in diesels to make you speculate in such a negative way.
  3. #93
    Adelaide hills, SA
    Quote Originally Posted by CardinalSin View Post
    Negative way?
    Not even Penrite, who makes the 2SO recommends using the 2SO in today's diesels. I bet you can say the same, what they know about it? To me they know enough. The 2SO is not a diesel fuel additive, in the case of the engine failure it would be looked at as a contamination.
    I guess people experiment a bit with a cheap cars, I bet they wouldn't use the 2SO as an additive in the brand new diesel car that cost close to $100,000 or more..
  4. #94
    Jan 2014
    N/A
    Negative way?
    Yes 'negative way' with no positive comments.
    VW do not support the use of any after market products, including Penrite diesel additives. That doesn't make them a bad product but if VW find they caused any problems then warranty will be denied.
    Much the same as altering the engine and gearbox management to increase power and torque limits. Clearly there is a trade off with higher loads reducing component life and increasing the risk of component failure which will also void warranty claims.
    Although I could be tempted to take that trade, it would certainly put me off buying a vehicle knowing the loads had been increased well above VW specs.
    However, a mild tune with EGR and DPF mods for economy and a trouble free future could be seen as a bonus. As could the use of 2SO for much the same reasons.
    I hope you regret your last comment as a mod in a forum where most members own those cars you refer to as 'cheap'.
    If you don't you should.
  5. #95
    Feb 2014
    Central Vic
    A lot of 'band width' going to waste me-thinks.
  6. #96
    Erskineville, NSW
    Quote Originally Posted by Ryeman View Post
    If you removed every off-topic, irrellevant, stupid, incorrect or doubled-up post on this forum (most forums) then there'd be nothing left.
  7. #97
    Feb 2014
    Central Vic
    I think kaanage knows what I'm on about.
  8. #98
    Adelaide hills, SA
    What negative comments? These are hard facts either you like it or not. There are many people who come here for an advice. I just try to make it clear that the 2SO is not a diesel fuel additive. It's your choice if you use it.
    If you use a purpose made diesel fuel additive in your diesel and VW refuses your warranty (I doubt that), then you can at least go to that product manufacturer and if they're at fault they will pay for the repairs. But, if you've used the 2SO, you're on your own, do you realised that?
    As for my comment "a cheap car" - I stand behind it, if you bought your car as secondhand, then you're more likely to take the risk and experiment a bit with the 2SO or something else. Though when your car breaks down, the cost of repairing it could be just as big as for a brand new one. I guess some people don't think about it that way.
    ...and definitely no regrets, anyone can buy for what ever purpose a cheap car as a second car or even their first car.
  9. #99
    Gosford Central Coast NSW
    Don't you guys have some work to do? Its not the weekend just yet!
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  10. #100
    Oct 2010
    Melbourne, VIC
    Sorry Aydan but...
    Exactly. You haven't tried it and found all these negative effects that you speculate about nor disproven the positive effects that others have experienced first hand so your comments are SPECULATION which gldgti asked quite specifically for people to avoid.
    What negative comments? ]
    The following is quite clearly a negative statement
    If your diesel engine seats for 2/3 weeks then you have to also think about the other tasks that proper diesel fuel additives do. Like fighting the bacteria, dispersing water from the fuel system making it safe to pass for the delicate surfaces in the modern diesel fuel systems and much more.
    None of this is possible with the 2SO.
    No, you go beyond that and make statements that 2 stroke oil cannot have any beneficial effects when added to diesel speculate about damage which has never been recorded in any other threads on various sites that Cardinal Sin, myself and others here have traversed before we each made our personal decision to try 2 stroke oil as a diesel additive and in each of our cases, have found positive effects with no damage or other downsides.
    If you don't try it because "you know" it won't work and will cause damage, then your comments remain as speculation, not "hard facts"
    The single "hard fact" that you have presented is that "2SO is not a diesel fuel additive" and even that statement should be qualified as "2SO is not a specifically developed diesel fuel additive"
    Yes I do and your contribution here is even less useful than on the diesel thread where the Skoda is having fuel consumption problems due to a fault.
    Resident grumpy old fart
