Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: 2.0TDI engine conversion into suzuki
    Gosford Central Coast NSW
    Quote Originally Posted by joelywil View Post
    the engine is the 103kw common rail TDI 2.0L
    should put out a fair amount more torque that the original 1.3 banga ha
    not really getting anywhere with this conversion atm. hmmmmm
    ah so we think that a HKS's F-Con stand alone ECU might be the ticket?
    if so who will tune the sucker? that will cost the moon ay.
    how much are one of those puppies going to set me back?
    might be the only way i can get the old girl out of static mode,
    not really quite sure how else it can done.
    just working at getting the engine mounted in the donk atm
    i appricate all the input guys, any thought and comments always welcome ay
    joel
    Here's my thought - try and find an amarok gearbox... probably cheaper and less hassle than afternarket ecu in the long term.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Oct 2011
    victoria
    true they are mounted the correct direction but then i will have to get the ecu and g box,
    so another whole wreck....just going to try and get this setup to run first,
    hopfuly i can trick the auto computer to think its running forwards.
    that will be the ticket,
    this is good were getting a tool box of ideas
    joel
    Here are the F-Con installers: Doesnt seem like any in VIC - might be worth calling the importer!
    Authorised Dealers
    Feb 2006
    what about 2009 tiguan wreck with 6spd manual 2.0 tdi 4wd common rail... key ignition ecu speedo...it starts and (not really drives) its a bit in the air....to many things in the head so i give up... if someone is willing to try it... this is it
    Oli
    Dec 2008
    Northern Suburbs
    HPA Motorsports Inc. VW TDI Powered Jeep
    different but relavent, may help.
    Oct 2011
    victoria
    howdy oli, tell me more about this wreck u have.
    why is it immobile and and what condition is the engine and gearbox in?
    i could use the gear box and engine as a combination and fit it to my defused transfer case
    in the suzuki, would be interested in hearing from you,
    thanks fellors for the ideas keep them rolling in
    joel
    Oct 2011
    victoria
    ok been busy in the last year but this is how far ive got with the the old girl
    2009 VW 2.0TDI engine going into suzuki sierra/samurai - YouTube
    just got the engine pulled out the jetta with the main dash and engine harness. got it all layed out across the concrete with modules.
    the engine is on the engine hoist. has to rewire the starting system and the fuel pumps to reprime the diesel koz stupid VW need to have it at their service agent with scan tool to reprime using activation of the tank and AUX pumps. i bypassed it all by runing pumps on IGN. havnt tryed selecting drive yet but will see how it goes. will keep you guys updated. now its time to fit to the suzi
    joel
    nice work joel - good to see some progress! Inspiring too, I've been thinking along these lines for a mk1 for a little while now
    thanks for updating us!
    '99 A4 Quattro 1.8T
    Nov 2005
    Sydney NSW
    oooh my... that looks like a 125TDI ???
    That's mighty ballsy of you for a Little Sierra!
    I wannt see some 4wd drifting after you finish with that!
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
