Results 1 to 10 of 15
Thread: 2.0L BKD - difficult to start hot
    Jan 2013
    Bought an 08 TDi Golf a few months ago. After I bought it I found it would crank for 10 seconds before starting, or not start at all when hot! Tested the battery under crank and found it dropping to 9.5V. Replaced battery with Varta original.
    Now, it starts almost instantly when cold, but seems to crank for 3 or 4 seconds when hot and starts with a jerk. It's never let me down since the new battery, but it still isn't quite right.
    It drives and operates flawlessy otherwise - a great car.
    Has anyone else had this problem and/or solution?
    Hot start issues are fairly common with the bkd engine.
    have you had it scanned for any fault codes?
    MKV Golf 2.0 TDI DSG Sportline. Just nice.
    Jan 2013
    yeah, it's the first thing I did. No fault codes.
    Dec 2008
    Sydney/Canberra
    What's the state of the intake flap and EGR valve like?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2013
    intake flap operates normally, and there are no EGR DTCs. I'm pretty sure the EGR would log a DTC if it didn't operate normally.
    Intake manifold inner walls are thinly covered with the normal carbon buildup.
    I've read on other forums (USA) that the starter motors wear internally and this reduces the cranking speed. The engine code is different over there. Is this starter fault a problem in Australia too?
    Jan 2013
    Dec 2008
    Sydney/Canberra
    There are starter motor-related issues, as well.
    Basically, the injectors won't inject if the starter motor can't turn the engine any faster than 280rpm.
    '01 Beetle 2.0
    Nov 2007
    Are you waiting at least a 2-3 seconds for the glow plugs to warm up before turning the key?
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    Jan 2013
    Yep, tried combinations of not waiting for glow plugs, waiting until lights extinguish, and reheating 2 or 3 times before cranking. It doesn't seem to make a difference to the hot start problem.
    In any case, it only happens when the engine is at operating temperature. This fault can occur literally seconds after I switch it off after a good drive.
    I could understand if it struggled to start when cold, but this goes against everything i've ever learned. The battery should be slightly above normal charge and cylinder compression will be at its highest. If it also struggled to start when cold, I would have a better chance of finding the problem... but I'm stumped!
    280RPM huh? Do you have any more info on this?
    Dec 2008
    Sydney/Canberra
    If you have a way of measuring the cranking speed, you'll be able to confirm this.
    Basically, the technical bulletin went on to say; if the battery is good, but the cranking speed is less than 280rpm, replace the starter motor.
    '01 Beetle 2.0
