Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 125kw TDI Golf MkV BMN - Engine Speed Sensor (G28) and P3138 Intake Manifold Dev Errs
    Apr 2008
    That's it.
    It's for readouts only. I use it to see what my DPF is doing, and other temps, but that's it.
    I got it mainly for a speed readout from the ABS sensor, so it's accurate as possible, rather than the needle which is way off.
    Here's a regen happening
    Attached Thumbnails Attached Thumbnails 125kw TDI Golf MkV BMN - Engine Speed Sensor (G28) and P3138 Intake Manifold Dev Errs-glgkawj-2-jpg   125kw TDI Golf MkV BMN - Engine Speed Sensor (G28) and P3138 Intake Manifold Dev Errs-dpf_regen-jpg
    Oct 2018
    Sydeny
    Thats awesome - definately getting one - found one in germany for about $350.
    About to put the replacement Darkside Alloy inlet conversion kit in today.. replacing the plastic version. My son is helping - wish us luck lol..
    I'll post how it goes, in case anybody else is interested.
    Jul 2011
    Perth
    Just like to add to this , as owner of GTd BMN Mk5 I had lots of experience with G28 sensor and other mentioned components.
    Quickly just on price of VCDs cable is not 300 but in $600US
    G28 sensor error on BMN engine will always throw a bad code in any bad cranking attempt ...
    Bad injector will reflect bad crank and throw G28 error
    Bad starter motor will not register on VCDs but will throw the same G28 error on cranking
    EGR will he associated with same attempts resulting in starving the engine and Computer reading same G28 error. However the VCDs will log EGR sensor readings.
    Oct 2018
    Sydeny
    Quote Originally Posted by ak77 View Post
    Thanks for the info - its a problem child this car.. but fun when it isn't doing a regen (every 3 days)
    My VCDS cable is the 3 car edition USB and cost 199-299USD
    HEX-V2 Enthusiast | Ross-Tech
    I did change the manifold to the alloy one, works beautifully, but make it impossible to take out the oil filter properly, you have to pop the lid of the filter and then remove them seperately! - the alloy has a large overhang..
    I still cannot beleive that teh DPF gets to 40% in 3 days of slow driving to work (about 15-30 mins in traffic each way)
    Oct 2018
    Sydeny
    G28 Sensor replacement - TDI 2.0 BMN
    SO I just got this error again after having the sensor replaced 6 months ago, and I think you are right. Cranking issues throwing a g28 error don't necessarily mean its a G28 sensor error...
    I am cranking on cold and hot starts, maybe 3 to 4 3 second attempts before firing. Some longer.
    Been though a few diagnostic videos, fuel pump, filter, VVT (not sure I have this though) - not sure what to do yet.
    Adelaide hills, SA
    Quote Originally Posted by Pete N View Post
    Maybe it’s a time for new battery.
    Jul 2011
    Perth
    Look at the starter motor , then battery
